Anyone Still Using OS2 Boot Manager?
redsun
PostPosted: Fri Jan 23, 2015 2:59 pm    Post subject: Anyone Still Using OS2 Boot Manager? Reply with quote
I used to have the OS2 boot manager to mange the multi boots. That was Windows 95 days. Does it also work with Windows 8 and OPENSTEP?
Asus P4S533 P4 @2400 Mhz, 512MB RAM, Matrox G400, 3Com 905, Adaptec 2940
hd0: 2GB, hd1: 4GB/2GB/2GB, hd2: 2GBx4
sd0: CD, sd1/2/3: HP 2GB x 3
PostPosted: Sat Jan 24, 2015 8:51 pm    Post subject: Re: Anyone Still Using OS2 Boot Manager? Reply with quote
I know it'll handle up to 4 operating systems as I did a system with open step, windows XP, Linux red hat and beos . I have not tried it with Windows 7 or 8 but I seem to recall having to install everything in a specific order and having to toggle partitions in FDisk , I think the Openstep partition had to be the primary boot partition . Other considerations were the size of the hard drive and having to write disk tab entries. Usually a 9 gb drive with ~2gb partitions is safe but going above that it initially will install but on a hard shut down everything goes haywire. I know some of the guys have 36 gb drives using Openstep writing disk tab entries for 4 gb partitions but I'm not sure how that would play into a multi operating system installation. They never thought drives would be above 2gb when they wrote the original kernal which causes the chaos as the operating system doesn't understand larger disk drive geometries . you see examples of this when using build disk and hook up a second disk and it'll list it as 0 bytes then it tries to initialize it as a swap file disk. There is a way to run custombuildisk from terminal app instead of launching build disk app which over rides build disk but I lost my raw doc on it. If someone has the custombuilddisk procedure let me know and I'll upload to the archive . Best regards Rob Blessin
PostPosted: Sat Jan 24, 2015 10:53 pm    Post subject: Reply with quote
I run it on my model 95 PS/2 to switch between PC-DOS/Windows 3.11 and Warp 3.
redsun
PostPosted: Sun Jan 25, 2015 12:28 pm    Post subject: Reply with quote
I looked at my note, which was dated 1997. That was OPENSTEP/OS2/Win95 triple boots. All the NeXT and FAT partitions were less than 1GB.
I just tried it now with WinXP and I have not figured it out yet. After I installed WinXP, it installed NT loader and I can't add WinXP onto OS2 boot manager. I can use FDISK to toggle active to boot manager, OS or WinXP. But I can't get boot manager to manage both OS4.2 and WinXP. I'll have to dig more into WinXP boot manager.
