Sound Blaster 16 PCI: Can't Control Sound Volume
redsun
PostPosted: Sun Feb 22, 2015 10:27 am    Post subject: Sound Blaster 16 PCI: Can't Control Sound Volume Reply with quote
I just installed this card and the driver works fine. Thx for the nice work.
Somehow I can't control the sound volume. I've set my speaker volume to the lowest, but the sound is still very loud. If I turn the sound volume knob up, sound is louder. So I know the speaker volume control works.
Is there anyway I can change the sound volume inside the driver? I think the sounder from the PC is just too loud.
Asus P4S533 P4 @2400 Mhz, 512MB RAM, Matrox G400, 3Com 905, Adaptec 2940
hd0: 2GB, hd1: 4GB/2GB/2GB, hd2: 2GBx4
sd0: CD, sd1/2/3: HP 2GB x 3
Morgon
PostPosted: Wed Feb 25, 2015 1:53 pm    Post subject: Re: Sound Blaster 16 PCI: Can't Control Sound Volume Reply with quote
Hello redsun,
that's a strange thing. Initially I wrote the driver for a real SB16PCI and never had problems with the sound being too loud. Therefore I can give no definite advise how to tweak the driver.
You might have a look at -updateOutputAttenuation in SoundBlaster16PCIDriver.m as that is the method used to get the current settings from the NeXT-System and set it to the driver part in es1371.m As the NeXT attenuation ranges from 0 to -84 while the driver expects values from 0 to 63 a conversion is been done. Maybe you can try a different conversion approach to get better results.
Hope this will help you a bit.
Morgon
