Best vm or emulator for NS 3.3 Intel?
ardi
PostPosted: Tue Mar 03, 2015 9:31 am    Post subject: Best vm or emulator for NS 3.3 Intel? Reply with quote
Which one (VMWare or Virtualbox) is more complete and stable for running NeXTSTEP 3.3?
Alternatively, has anybody tried it with Bochs or PCem?
I'd like to have network emulation, sound, and stable graphics, mouse and keyboard.
What virtual machine or emulator would you recommend for getting the most stable and complete working system?
Thanks!
PostPosted: Tue Mar 03, 2015 10:46 am    Post subject: Reply with quote
I use VMware Fusion, and it works great for everything except sound.
ardi
PostPosted: Tue Mar 03, 2015 1:58 pm    Post subject: Reply with quote
Why? Doesn't NeXTSTEP support the Sound Blaster on Intel PCs?
PostPosted: Tue Mar 03, 2015 2:20 pm    Post subject: Reply with quote
It does, but the driver does not work in the latest versions of Fusion.
jvernet
PostPosted: Tue Mar 10, 2015 1:22 am    Post subject: Reply with quote
I recently (this WE) tried to install Openstep 4.2 on VMWare Fusion 6.0.5 (MacOsX 10.9) and VirtualBox 4.3.24 on W7:
- Fusion: no sound, working network, working screen at 1024x725 with VMwarefb1.1.1 driver, mouse working with VMouse. Crash (blue screen with an inverse 'u' in left corner) when selecting a better resolution.
- VirtualBox: sound, no network, some graphical glitch with VESA VBE drivers at 1024x7268
i will give a try for Rhapsody DR2 soon.
Apple & NeXT
PostPosted: Tue Mar 10, 2015 3:49 am    Post subject: Reply with quote
jvernet, I forget how I did it, but I had OS 4.2 running at 1280x1024 with that driver. I think you have to edit a file manually to set the resolution, but maybe I'm thinking of the manual config for the mouse.
pitz
PostPosted: Tue Mar 10, 2015 8:39 am    Post subject: Reply with quote
I use VirtualBox on W8.1 for running OPENSTEP 4.2 and Rhapsody DR2, though not extensively. Can you provide additional details on the VESA driver glitches you've observed?
jvernet
PostPosted: Tue Mar 10, 2015 9:40 am    Post subject: Reply with quote
Some horizontal lines sometime, when moving windows, that stay on screen for few second. Mouse pointer sometime leave some pixel around, also. Not very important.
The most annoying problem I am face is that mounting ISO image as CDROM do not work all the time. I may try to connect the virtual drive to an SCSI card, if I can.
mount do not work, need to reboot, and sometime more than once.
Apple & NeXT
pitz
PostPosted: Wed Mar 11, 2015 8:49 am    Post subject: Reply with quote
Thanks for the info on the video glitches -- I'll watch for them on those occasions that I bring up my OPENSTEP virtual machine.
Regarding the mounting problems, I've definitely encountered issues with older versions of VirtualBox. With the latest version of VirtualBox, the only issue I've had so far was that with high-end faster host systems, the out-of-the-box OPENSTEP EIDE driver would sometimes generate errors. Upgrading to the EIDE drivers in the Beta Drivers disk fixed those errors.
jvernet
PostPosted: Wed Mar 11, 2015 12:58 pm    Post subject: Reply with quote
Witch version should be the best ?
I tried with different ones which seems to work also, but not from the beta drivers disk.
These drivers may also work with Rhapsody, isn'it ?
Apple & NeXT
pitz
PostPosted: Wed Mar 11, 2015 6:12 pm    Post subject: Reply with quote
If you could get the PIIX (v4.03) device controller to load, it should provide better performance. Otherwise, the standard primary/secondary dual EIDE controller (v4.03) also works. Both from the OS 4.2 beta drivers diskette. I haven't attempted using them in Rhapsody.
