Modified ADB to nonADB + VGA and 152 power supply support
Post new topic   Reply to topic    NeXT Computers Forum Index -> Classic Computer Marketplace
PostPosted: Sat May 09, 2015 4:11 pm    Post subject: Modified ADB to nonADB + VGA and 152 power supply support Reply with quote
I listed a full kit on ebay. New caps, and additional board to support older 68030 cubes included.
http://www.ebay.com/itm/271865367436?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
PostPosted: Wed Aug 12, 2015 10:52 pm    Post subject: Re: Modified ADB to nonADB + VGA and 152 power supply suppor Reply with quote
Hello Brian: that 152 power supply load board is cool , do you have a parts list and how to for do it yourselfers. Thank you ! Best regards Rob Blessin
PostPosted: Wed Aug 12, 2015 11:43 pm    Post subject: Reply with quote
5w halogen bulb (The same kind used for kitchen appliances)
perfboard cut to size
3 pin standard female header (bulb socket)
96 pin connector (right angle connector which is the harder one to find)
A bit of wire
Use the -12V line for the negative terminal and the GND connection for the positive terminal on the bulb. Use some glue on the 96 pin connector to handle the stress of connecting/disconnecting. You'll have to very slightly bend the pins on the bulb to get them to fit. You'll probably break a few figuring out the right stress to use. Do not use anything above 5W.
PostPosted: Thu Aug 13, 2015 2:46 am    Post subject: Reply with quote
Suppose you miss having black hardware, how much of a cube do you really need to get something going? If I had an 030 board, could I interface this bulb directly do the boards NuBUS backplane along with voltage?
Just curious.
PostPosted: Thu Aug 13, 2015 9:47 am    Post subject: Reply with quote
Bare minimum all you need is a motherboard and power supply, yes.
Post new topic   Reply to topic    NeXT Computers Forum Index -> Classic Computer Marketplace All times are GMT - 7 Hours
