Previous for Raspberry Pi?
PostPosted: Fri Aug 28, 2015 10:39 pm    Post subject: Previous for Raspberry Pi? Reply with quote
Has anyone tried cross compiling? Seems like an excellent use for a Pi 2, ADB keybiard converter and one of Rob's hollow slab cases.
Noth
PostPosted: Sat Aug 29, 2015 5:07 pm    Post subject: Reply with quote
Last time I tried, back when gfx started working, it compiled fine natively, no run to crosscompile. Give it a go, it's not hard!
pergamon
PostPosted: Sun Aug 30, 2015 2:21 pm    Post subject: Reply with quote
Whoa, really? That's crazy and awesome. I will do this.
jvernet
PostPosted: Mon Aug 31, 2015 2:05 pm    Post subject: Reply with quote
Hatari run on the PI, but Falcon emulation is unusable, even on a overclocked PI. Too slow...
ST emulation work fine, so I think Previous will be too slow, but may work...
Apple & NeXT
PostPosted: Thu Nov 03, 2016 11:03 am    Post subject: Reply with quote
Has somebody got NeXTstep/Previous to work on a Raspberry Pi? I'd like to run it on a new 3B model.
pitz
PostPosted: Fri Nov 04, 2016 10:07 am    Post subject: Reply with quote
Yes on the RPi2: http://www.nextcomputers.org/forums/viewtopic.php?t=3847
But it was only able to run to about 33% of real hardware speed. The RPi3 might be able to boost it up to around 50%.
PostPosted: Fri Nov 04, 2016 10:23 am    Post subject: Reply with quote
Thanks for the link. I'd like to do the same with a 3D printed Cube enclosure I bought on eBay.
Can you give me a few hints about what has to be done to compile Previous on the Pi? I used toi be a developer but that is long ago...
TIA
PostPosted: Sat Nov 05, 2016 6:01 am    Post subject: Reply with quote
Was asked about the 3D printed Cube enclosure. It's a guy from the UK, you can buy it on eBay: http://www.ebay.com/itm/NeXT-Cube-Raspberry-Pi-Case-/131977820271.
It seems to have some rough edges but let's see how it looks in person.
PostPosted: Sat Nov 05, 2016 5:56 pm    Post subject: Reply with quote
Wow, that's really neato! If I get a raspi I'll definitely need to get that case!
Thanks!
pitz
PostPosted: Sat Nov 05, 2016 8:53 pm    Post subject: Reply with quote
TIA
Mainly followed gilles' instructions from the main forum thread for Previous, linking to his site: http://previous.alternative-system.com/index.php/build
For Raspbian, the packages you would need to build are cmake and libsdl2-dev (SDL). The latest Raspbian stable package repository already has SDL 2.0.4. If you need to make use of the new audio stuff that's only available with SDL 2.0.5, you'd need to add Debian's sid/unstable package repository to your package sources. Or maybe build SDL 2.0.5 directly from sources.
PostPosted: Sun Nov 06, 2016 5:25 am    Post subject: Reply with quote
Ok. Have you tried building SDL so that it directly renders into the frame buffer (no X-Window)? Should be faster.
