NeXT Megapixel Color 17 Repair
brooklyn
PostPosted: Wed Sep 07, 2016 8:59 pm    Post subject: NeXT Megapixel Color 17 Repair Reply with quote
Hi, I have a NeXT 17" Color Megapixel display that was included with a nextstation I bought. The monitor was sold as not working.
When I got home and tried it, I heard the CRT energize, but immediately some magic smoke escaped, so I quickly turned it off.
On disassembly I found some cooked components on what looks like the video out board. See pictures. I ordered replacement components to solder on, but I wonder if another issue caused these components to go out?
Any ideas? Question Will update when I have a chance to replace the burnt components later this week.
PostPosted: Wed Sep 07, 2016 9:24 pm    Post subject: Reply with quote
I think it's likely if you just replace those components and power it up you will blow the new ones as well. I have no idea as to the full purpose of this board, but as I see it, each signal (RGB) has a cloned set of circuitry. Knowing that you should be able to check the values and compare across the components even in circuit to get a general idea of what else could be failing. I would immediately suspect the electrolytic cap of drying out and shorting. Secondly I would be suspicious of those transistors, followed by the diodes.
crispin
PostPosted: Thu Sep 08, 2016 10:47 am    Post subject: Reply with quote
I believe NeXT sold two kinds of 17" monitors. One was a Sony and the other was Hatachi. The Hatachi monitors were horrible and failed frequently. I myself went through 2 of them in the 90s.
brooklyn
PostPosted: Mon Sep 12, 2016 10:15 pm    Post subject: Reply with quote
I think it is an Italian monitor. I replaced the damaged components and now the monitor turns on, however there is no horizontal or vertical sync. It's either the video in board that I repaired earlier, or a problem on the deflection board. I inspected both boards visually and there is nothing obvious.
Any tips? Does anyone have any spare boards from Megapixel Color 17 monitors?
[/url]
PostPosted: Mon Sep 12, 2016 11:42 pm    Post subject: Reply with quote
Great effort , I sent you a PM. Best regards Rob
