Rhapsody 1.2v3 Power Mac G4 AGP
hexloo
PostPosted: Mon Feb 13, 2017 7:59 am    Post subject: Rhapsody 1.2v3 Power Mac G4 AGP Reply with quote
Hi, I'm trying to install Rhapsody 1.2v3 on this machine. I'm using a 2 GB IDE drive set to master and the first installer when you're booted into OS 9 sees it, but when I restart, it doesn't detect it after the language selection is done. I've updated the hard disk drivers and stuff to no avail.
This is what it shows:
http://i.imgur.com/vQT0QAm.jpg
Here is a video:
https://youtu.be/X_QXq5qIS_s
I got close to the computer at the Scanning Disk part so you could hear the thunkthunkthunkthunkthunk noise but it didn't come out very well, lol.[/url]
SlateBlue
PostPosted: Mon Feb 13, 2017 12:17 pm    Post subject: Reply with quote
Did you use the OS 9 portion of the installer to initialize the hard drive?
hexloo
PostPosted: Mon Feb 13, 2017 2:08 pm    Post subject: Reply with quote
Yes, I now have it working, but only on a 500 mb hard disk, so there's not really room for anything. Is there some way I can get the other HD to work?
SlateBlue
PostPosted: Mon Feb 13, 2017 2:58 pm    Post subject: Reply with quote
What brand of drive is it? Rhapsody is pretty picky of what hardware it'll work with. I would try yet another hard drive.
hexloo
PostPosted: Mon Feb 13, 2017 3:24 pm    Post subject: Reply with quote
Okay, I just fixed it, but it was really weird. I'll tell you what I did so anyone else in my situation can do it as well.
Installing Rhapsody on an Incompatible/Non-Working w/ Rhapsody Hard Drive
Set compatible hard drive as master, set incompatible as slave. Format both and make sure they have updated disk drivers. Partition the incompatible drive as Mac OS Extended. Tell the live cd installer to install on your incompatible disk. Then, for some reason, the Rhapsody installer will work fine with it. I have no idea why, but anyways, it works. Some people have also said that the partition you select to install Rhapsody on must be 1 GB or under, but this is simply not true, at least in this case.
SlateBlue
PostPosted: Mon Feb 13, 2017 8:42 pm    Post subject: Reply with quote
Thanks for reporting back with your solution. Glad you got it working.
