NeXT N3010 CD-ROM Drive Problems?
pergamon
PostPosted: Tue Feb 28, 2017 5:29 am    Post subject: NeXT N3010 CD-ROM Drive Problems? Reply with quote
Has anyone else had issues with the NeXT external CD-ROM drives spontaneously failing?
I have many of them, including a couple that I know worked a few years ago and have just been sitting in my house since then. However, now none of them actually seem to be able to mount a disk. They'll take in the cartridge, it'll spin for a bit, but it never mounts. The same CD (a NeXTSTEP 3.3 Patch2 disk) mounts just fine using the same cartridge in a 3rd-party drive on the same NeXTstation so it has to be the drives and not the computer or disc.
Maybe there's some consistent age-related failure issue like with the ODs?
PostPosted: Tue Feb 28, 2017 8:29 am    Post subject: Reply with quote
It could be failing capacitors. see http://www.asterontech.com/Asterontech/next_cdrom_refurb.html
PostPosted: Tue Feb 28, 2017 1:28 pm    Post subject: Reply with quote
Yup. Its definitely capacitors.
pergamon
PostPosted: Wed Mar 01, 2017 8:44 am    Post subject: Reply with quote
Thanks for the info! I did a little searching around and didn't find this.
It's been a while since I've soldered, but since I have 10 of these I ought to be able to get at least one of them right.
nekonoko
PostPosted: Sun Jan 28, 2018 6:37 pm    Post subject: Reply with quote
I just refurbished mine this weekend; it needed new ceramics in the drive itself plus the electrolytics in the power supply had vented sticky green goo everywhere. It was a mess. Shocked
PostPosted: Mon Jan 29, 2018 9:41 pm    Post subject: Reply with quote
Yes. Please note that it is especially an issue with drives internal and external manufactured by Sony that they have their capacitors reworked. Sony in particular loved surface mount at this point and they ALL are at the point of failure now.
PostPosted: Tue Jan 30, 2018 12:15 pm    Post subject: Reply with quote
And as a result the price on this vintage of drive is getting out of control. I used to be able to pick up a parts drive for $25 or so.
PostPosted: Tue Jan 30, 2018 8:43 pm    Post subject: Reply with quote
I would of expected a "non-functional" (it needs a recap) drive would be cheaper than a working or already recapped unit.
Shuren
PostPosted: Sat Feb 24, 2018 10:33 am    Post subject: Reply with quote
https://drive.google.com/open?id=1olK3LyYpJ8l-KxlL5q-__xQPT4tSN9Ha
I'm sorry, but... "Can't read device capacity" meaning that Toshiba drive is unsupported?
Thank's,
Michele
Blog (in Italian): http://greedyandlounge.blogspot.com
View user's profile Send private message MSN Messenger
PostPosted: Wed Mar 07, 2018 10:54 pm    Post subject: Reply with quote
Toshiba's should be supported. What is your block size jumper set to on the drive?
Shuren
PostPosted: Thu Mar 08, 2018 11:33 am    Post subject: Reply with quote
I'm a little bit frustrated... Opening the external enclosure, I had can recognize the drive and jumpers: it is the XM-3501B from Toshiba. But there is no mark of block jumpers.
http://stason.org/TULARC/pc/optical-cd-drives/TOSHIBA-CD-ROM-XM-3501B.html
Here ( https://groups.google.com/d/topic/comp.periphs.scsi/U-XASRsD-Us/discussion ) I found a trace of a sort of switch for another model that change block size from "PC" to "Sun" mode, but nothing here... :/
Any ideas, hint or cocktail will be appreciated!
Michele
PostPosted: Thu Mar 08, 2018 12:58 pm    Post subject: Reply with quote
Yes setting the block size as I recall is not done with a jumper on these drives, but rather by cutting a trace. You want the 512K block size. This link seems to confirm my thinking:
http://rainbow.ldeo.columbia.edu/documentation/sgi-faq/hardware/40.html
