Goto page Previous  1, 2, 3 ... 13, 14, 15
PostPosted: Fri Apr 20, 2018 7:36 am    Post subject: Reply with quote
Are you reigniting your enthusiasm for additional tweaking of the Darwin sources?
Wink
I wish I could be more active but my only free time nowadays is consumed by redesigning my home network including the rack, wiring, firewall, UTM, NAS, etc. I am drowning...
PostPosted: Fri Apr 20, 2018 7:45 am    Post subject: Reply with quote
I have been stepping back through the process...
I need to document it more, it really is a mountain of "special" to be standing on...
That and pull in a whole lot of the rest of Darwin to get a better footing, along with leaning a lot more on Rhapsody......
It's been a year since I posted anything significant, and I'm dying to change that a little......
I also want to check out Visual Studio 2017 and it's "cross Linux" tools and see if it'll just ssh to any other OpenSSL host...
PostPosted: Sat Apr 21, 2018 7:29 am    Post subject: Reply with quote
Also I kinda worked around the weird installer thing and got Darwin 0.3 to install!
You need to install OS 9, I used the G4 Cube version, onto a disk. Then get the Darwin 1.0 CD image, and copy the disk imaging tool to the hard disk. Then using that tool, restore the image on the Darwin 0.3 CD onto a empty disk.
And then I used Steve Troughton Smith's BootX loader https://github.com/steventroughtonsmith/BootX
qemu-system-ppc.exe -L pc-bios -drive file=..\darwin03.qcow2,index=0,format=qcow2,media=disk -drive file=BootX_custom.dmg,index=2,format=raw,media=disk -prom-env "boot-device=ide1:2,\BootX" -prom-env "boot-args=-v rd=hd0 debug=0xffe kdp=2" -prom-env "boot-file=ide0:8,\mach_kernel" -M g3beige
Yes it does take a while to boot up, but yay now I can test feature parity between x86 and PowerPC
Oh yeah download link:
https://sourceforge.net/projects/aapl-darwin/files/qemu-images/Darwin03-PowerPC_qemu-2.11_04_22_2018.7z/download
Also here is Darwin 1.0
https://sourceforge.net/projects/aapl-darwin/files/qemu-images/Darwin1.00PowerPC_qemu-2.11_04_22_2018.7z/download
At least on Qemu Darwin 1.0 is significantly faster than 0.3 ..
PostPosted: Sun Apr 22, 2018 5:15 am    Post subject: Reply with quote
Q. But I heard Darwin OS runs on Intel PCs...
Most of Darwin code is platform-independant, and some of the platform-dependant code includes some support for Intel processor-based systems. There are, however, some parts of the system (eg. HFS+ and AppleTalk) which have not been ported to the Intel platform. The current Darwin release is compiled for PowerPC only, but it should be possible to bring up an Intel version with some additional work.
http://web.archive.org/web/19990821004420/http://publicsource.apple.com:80/projects/darwin/faq.html
Well that certainly explains a lot.
And the original 0.1 certainly was just some source files:
Q. What do I need to compile this code?
Presently, you need to buy and install a copy of Mac OS X Server with the developer tools. We are actively working on putting together a self-hosting binary distribution of Darwin so that you can install that as your development platform. This will include all of the needed development tools.
http://web.archive.org/web/19990508075706/http://www.publicsource.apple.com:80/projects/darwin/faq.html
PostPosted: Sun Apr 22, 2018 6:09 pm    Post subject: Reply with quote
Something I should have done years ago, but I guess no time like the present...
https://opensource.apple.com//tarballs/
mirror this directory.
# du -hs opensource.apple.com
26G     opensource.apple.com
Ever since the 'great reset' of Darwin with the release of 10.0 it really isn't that much to be honest..
https://opensource.apple.com/release/mac-os-x-100.html
PostPosted: Sun Apr 22, 2018 7:34 pm    Post subject: Reply with quote
I pulled all the tarballs for 10.0 through 10.5 back in the days when I was fiddling with cctools. I have them stored locally on my Synology NAS.
PostPosted: Sun Apr 22, 2018 8:14 pm    Post subject: Reply with quote
I wonder if anything went missing during this time..?
PostPosted: Mon Apr 23, 2018 5:33 am    Post subject: Reply with quote
I will make a file list when I have a chance...
PostPosted: Mon Apr 23, 2018 3:51 pm    Post subject: Reply with quote
Ok, here is the source package listings for 10.0 through 10.3:
https://www.dropbox.com/s/612bfsv2ke1xrhd/osx-source-list.zip?dl=0
Page 15 of 15
