Exception 3 error , what is it?
PostPosted: Fri Jul 14, 2017 3:59 pm    Post subject: Exception 3 error , what is it? Reply with quote
Hello NeXT Community: I'm getting exception 3 errors on Color station motherboards anyone know what they are , they all have old caps. Best Regards Rob Blessin
PostPosted: Fri Jul 14, 2017 4:08 pm    Post subject: Reply with quote
Can you tell what it prints exactly? Is it printed during kernel panics or on the ROM monitor?
Exception 3 is address error, meaning that the processor attempts to fetch an instruction from an odd address.
PostPosted: Fri Jul 14, 2017 7:23 pm    Post subject: Reply with quote
I've fixed a few logic boards with this condition by replacing the caps.
PostPosted: Fri Jul 14, 2017 7:25 pm    Post subject: Reply with quote
Also make sure you are populating the RAM in the right slot order. Slot zero is towards the edge of the board.
PostPosted: Fri Jul 14, 2017 8:23 pm    Post subject: Reply with quote
Hello Andreas and Brian: I was able to troubleshoot and identify the problem.
The key was having a separate NeXT slab .
As soon as I plugged the MicroSD into it with the same exception 3 error coming up I suspected the build image on the SD was bad.
I did a fresh DD image and it works. So I'm guessing anything with an exception 3 error has to do with either failing caps or a faulty hard drive or in this case a faulty microsd install.
So you we're right Andreas , the image was corrupt and Brian I think the first board has a failing cap as I see electrolytic fluid / My guess is the failing cap caused intermitant signals when the sd was booting probably corrupting the install on the sd , may be an electrical surge . I'm also guessing that this combo problem probably hoses a lot of hard drives just a theory.
Problem solved as it now boots on the color motherboards as well ... yeah. Thanks for your help!
PS I have those Color Turbo Boards I need to send you Brian, I'm going test them one more time and write notes.
