NeXTSTEP 3.3 on HP 743 SBC
PostPosted: Sun Dec 03, 2017 3:05 am    Post subject: NeXTSTEP 3.3 on HP 743 SBC Reply with quote
The hp743 is a 6U VME based SBC.
I tried to install the ns 3.3, however the kernel hangs with memory access exception:
PDC - Processor Dependent Code - Version 302.0 Release 0
(c) Copyright 1994, Hewlett-Packard Company, All rights reserved
 80 Mbytes of memory configured.
System Search started.
Press [Esc] to discontinue the Auto Boot process.
Pressing [Esc] will NOT discontinue Auto Boot.
Now booting.
LASI I/O detected
NEXTSTEP boot v3.3.4.17
81920 memory
NEXTSTEP will start up in 10 seconds, or you can:
  Type -v and press Return to start up NEXTSTEP with diagnostic messages
  Type ? and press Return to learn about advanced startup options
  Type any other character to stop NEXTSTEP from starting up automatically
Type 1 to use the English language and USA keyboard while installing NEXTSTEP.
Tapez 2 pour installer NEXTSTEP avec un clavier et des messages francais.
Eingabe 3 fuer NEXTSTEP-Installation mit deutscher Sprache und Tastatur.
Premi 4 per installare NEXTSTEP usando lingua italiana e tastiera italiana.
Pulse 5 para usar el idioma y el teclado espanol en la instalacion de NEXTSTEP.Skriv 6 for att installera NEXTSTEP pa svenska med svenskt tangentbord.
---> 1
This program is for installing NEXTSTEP on a hard disk.
If you have files on your hard disk that you want to keep,
quit this program and copy what you want to keep onto another disk.
Type 1 to prepare to install NEXTSTEP.
Type 2 to quit this installation program.
---> 1
Reading NEXTSTEP configuration
NeXT Mach 3.3: Tue Feb 14 20:55:37 PST 1995; root(rcbuilder):mk-172.3.32.obj~5/RC_hppa/RELEASE_HPPA
physical memory = 80.00 megabytes.
using 255 buffers containing 1.99 megabytes of memory
available memory = 72.63 megabytes. vm_page_free_count = 2451
attempting block map of 0xf0000000
attempting block map of 0xf8000000
Memory access exception (1,1,31769c)
Waiting for remote debugger connection.
(Type 'c' to continue or 'r' to reboot)
I noticed there were newer 3.3 hppa builds which could fix this issue. Any ideas?
