Cube 68030 Scrambled video on boot
krazycat
PostPosted: Tue Dec 12, 2017 1:16 pm    Post subject: Cube 68030 Scrambled video on boot Reply with quote
Hi
I have a 68030 Cube with booting problems. After I replaced the caps, the cube starts to a scrambled screen and the red LED on the board is flashing 4 times fast. I also replaced the RAM and the CPU without luck. Does anyone have the electrical schematics of the 68030 board, or any idea how to solve it? The problem could be the nvram chip?
This board was previously stored in a box for 20 years, I don't know if it was working.
Here the screen at boot:
PostPosted: Tue Dec 12, 2017 9:51 pm    Post subject: Reply with quote
Here are the LED code descriptions:
LED Blink Codes (LED on the logic board if system can not boot to ROM)
1,2 ROM CRC check failures
3 Bad VRAM
4 Bad NVRAM (The NVRAM store in the clock chip)
5 No usable DRAM
Try removing the battery and reseating the ROM chip. Did you desolder the CPU? I've never seen a socketed 68030. There are no schematics for this board.
krazycat
PostPosted: Wed Dec 13, 2017 3:46 pm    Post subject: Reply with quote
3 Bad VRAM
5 No usable DRAM
Thanks for codes Brian.
Sorry for the mistaken, I was wrong to write. I also replaced the RAM and the ROM (NOT the CPU) but I did not have luck... Embarassed
PostPosted: Wed Dec 13, 2017 11:07 pm    Post subject: Reply with quote
My experience with these symptoms has unfortunately not been good. I've seen this with bad CPU's and with bad NeXT ASICs. Both require a significant amount of effort to rework. If you don't have an emotional attachment to the board it may be easier to buy a new one. You can see an example here:
http://www.nextcomputers.org/forums/viewtopic.php?t=3875&highlight=led+code
krazycat
PostPosted: Thu Dec 14, 2017 12:50 pm    Post subject: Reply with quote
Thanks for your support, I'm not particularly attached to this board so if the replacement of the MC68HC68 Real-Time Clock (a SO16L chip) will have no effect, I'll look for another motherboard.
Does anyone have a working 68030 board to sell at a reasonable price? Mr. Green
PostPosted: Sun Dec 17, 2017 4:12 pm    Post subject: Reply with quote
Hello Krazycat: I've had that happen with non compatible ram, try putting the old ram back in.... I have a 68030 25Mhz for $99 or with new professionally replaced caps $164 , tested / compatible ram $1 a mb in sets of 4. Also which version of the rom did you use as 030's tend to be finicky? Best regards Rob Blessin
krazycat
PostPosted: Mon Dec 18, 2017 1:30 am    Post subject: Reply with quote
Hi Rob, for testing I used RAM and ROM Release 1.1 from a working 030 cube from a friend of mine. Thanks for your offer, if after the last tests my board will not work, I will write to you to buy a $ 99 board.
krazycat
PostPosted: Fri Jan 19, 2018 8:27 am    Post subject: Reply with quote
This story has a happy ending: I had the MC68HC68 Real-Time Clock chip replaced, and now the cube works!
PostPosted: Fri Jan 19, 2018 1:54 pm    Post subject: Reply with quote
Nice work!
PostPosted: Sat Jan 20, 2018 7:05 am    Post subject: Reply with quote
Very good! And good to know another fix for our beloved NeXT's.
krazycat
PostPosted: Sat Jan 20, 2018 10:43 am    Post subject: Reply with quote
And now to complete this cube, I have to find a power supply and a backplane (this revived motherboard has been tested on a friend's cube) Very Happy
PostPosted: Mon Jan 22, 2018 10:58 am    Post subject: Reply with quote
Hello: I have a working NeXT Cube model 152 power supply for $99 and internal backplain for Used $20 or $30 New Old Stock, do you need the drive harness as well $25? Best Regards Rob Blessin
