New ADB Soundbox replacement
PostPosted: Sun Mar 04, 2018 1:46 am    Post subject: New ADB Soundbox replacement Reply with quote
Hi All,
Thought I'd post a little teaser of a project I've been working on. I call it the NoSoundADB board. Basically it's an ADB sound board without the sound.
Keyboard and mouse work perfect. Now I'm focusing on video.
PostPosted: Sun Mar 04, 2018 7:03 am    Post subject: Reply with quote
That's a very neat project.
I think it's exciting to see the new projects going on, from this one to the NeXT-USB adapters.
PostPosted: Sun Mar 04, 2018 10:38 pm    Post subject: Reply with quote
Hello Brian: Awesome stuff , let me know when they are ready and will there be a non adb version as well? Best Regards Rob Blessin
PostPosted: Mon Mar 05, 2018 1:51 am    Post subject: Reply with quote
I would like to eventually do something similar for the non-ADB, but that will be more complicated. Personally I almost never use sound on my systems anyway. Giving that up simplifies the problem tremendously.
PostPosted: Mon Mar 05, 2018 10:47 pm    Post subject: Reply with quote
Did some additional work tonight. Everything seems to be working now. I'll need a board revision with some fixes.
A couple notes:
1) this device will fail the sound test at boot. This should be disabled in the PROM. This is the default state.
2) The original next straight cables may not have the ADB pin connected. I think all the Y cables are fine. I forgot this and wasted a lot of time....
I'm pretty happy with the results overall.
krazycat
PostPosted: Tue Mar 06, 2018 9:14 am    Post subject: Reply with quote
Great project, very useful since the original Soundboxes are so rare. If you produce the NON-ADB version, I would buy two (and two megaloads) Cool
PostPosted: Tue Mar 06, 2018 9:24 am    Post subject: Reply with quote
this thingy does only work for the mono turbo slab since others doesn't support ADB devices?
PostPosted: Tue Mar 06, 2018 9:52 am    Post subject: Reply with quote
Correct, this requires a turbo system: mono, color, or cube. The video out will not work on a color system.
PostPosted: Tue Mar 06, 2018 10:44 am    Post subject: Reply with quote
Why is that so? Isn't it just some other pins you need to route from the DB-19 connector to the keyboard output?
PostPosted: Tue Mar 06, 2018 11:24 am    Post subject: Reply with quote
The non-adb signal needs to be syncronized to monitor clock. I think I recall it working at 5mhz which complicates using a microcontroller.
PostPosted: Tue Mar 06, 2018 11:37 am    Post subject: Reply with quote
You mean one has to pick up the signal from the keyboard and mouse and then sync it with the monitor clock to pass it to the NeXT?
PostPosted: Tue Mar 06, 2018 3:17 pm    Post subject: Reply with quote
I'm hoping that's all there is to it, yes.
PostPosted: Tue Mar 06, 2018 4:00 pm    Post subject: Reply with quote
Hello Brian: This is all cool stuff , would it be possible to add something similar to Drak's USB adaptor ... obviously the ultimate toggle switch options would be choice of USB or ADB or NON ADB peripherals to bring sound back in some sort of NeXT PCB sound board emulator that would plug into your box USB ?
https://www.mouser.com/ds/2/737/adafruit-proto-shield-arduino-932880.pdf or check this out https://www.adafruit.com/product/2133 Best regards Rob
PostPosted: Mon Mar 12, 2018 8:11 pm    Post subject: Reply with quote
New board came today:
Keyboard and mouse are working well. The video seems a bit fuzzy, but that could be my cable and not the board. I'll need a properly shielded cable to confirm. Either way, the video is probably not very useful anyway.
So where to go from here? Well at this point I'm not going to waste the 19pin connectors on this board. I've gotten quite a bit of encouragement to move on to the non-ADB version. Nothing is wasted because I'll need everything I learned here to continue on. As I stated before, this becomes a software problem as well as a hardware one. In addition the megaload functionality will be integrated into the board as well (that part is easy and already done). No promises on timeline, but I'll try to post updates when it's meaningful.
PostPosted: Tue Mar 13, 2018 1:36 am    Post subject: Reply with quote
As far as i understood, this board makes it possible to power on a Turbo slab and use it with (Apple)? ADB keyb/mouse and VGA video - or not?
So i think the video-out is essential.
