Running Previous 2.0 w/ NS3.3 - trying to get networking up
blakespot
PostPosted: Fri Apr 20, 2018 11:12 am    Post subject: Running Previous 2.0 w/ NS3.3 - trying to get networking up Reply with quote
I have Previous 2.0 on Windows and a NS3.3 .dd volume I downloaded and after following the instructions for setting up networking that came with the .dd, I see the EN light blink a bit and when I
telnet bbs.fozztexx.com
The command sits there thinking and the EN light blinks, but nothing happens. So it's somewhat setup correctly. I followed these instructions:
Quote:
Howto: Setup networking on NeXTstep 3.0 and later:
1. Use Simple Network Starter (you find it in the NextAdmin directory)
and set up some values:
a Check "Provide the services specified below."
b Choose a hostname (whatever you want).
c Set IP address to "10.0.2.15".
d Go to "Network Options..." and set
Router to "10.0.2.2"
Broadcast Address to "10.0.2.255"
Netmask to "255.255.255.0" and
NIS Domain Name to "None".
e Hit configure. You will be prompted to connect the Ethernet
cable.
f If not already done, connect emulated Ethernet now using
Previous' GUI and hit OK.
2. Using root access rights open and edit these files:
a /etc/hostconfig and replace "-ROUTER-" with "10.0.2.2".
b /etc/resolv.conf and add "nameserver 10.0.2.3".
If this file does not exist, you have to first create it.
Be sure you create a plain text file. If you use Edit.app
you can do this by selecting Format > Text > Make ASCII.
Howto: Open the above files using root privileges (NeXTstep 3.3):
a Open the /etc directory with this command in Terminal:
"open /etc"
b Select the file/application to open and from Workspace select
Services > Open Sesame > Open As Root.
c For making a new resolv.conf open Edit.app the same way (b)
and in the save dialog type as name "/etc/resolv.conf"
3. Reboot.
(I used vi from terminal to edit, fwiw.) But -- not quite working. Any ideas? Thanks.
bp[/quote]
:::My NeXTs:
- NeXTstation Turbo Color w/ 21" NeXT CRT (NS3.3)
- HP 712/100 "Gecko" (NS3.3)
http://bytecellar.com
PostPosted: Fri Apr 20, 2018 10:14 pm    Post subject: Reply with quote
start with the basics..
with SLiRP the only thing you can ping is the gateway, see if that works.
ping 10.0.2.2
I think NeXTSTEP should have nslookup, try to resolve a DNS name...
blakespot
PostPosted: Sat Apr 21, 2018 6:16 am    Post subject: Reply with quote
ping 10.0.2.2
Well, first ping isn't on the system. I'll need to get that solved first. Smile I will look into mounting a shared volume thru Previous, which I'm guessing is possible.
bp
:::My NeXTs:
PostPosted: Sat Apr 21, 2018 6:28 am    Post subject: Reply with quote
Ping is normally present on a NeXTstep 3.3 installation. But on my system it is not recognized, if I am running it as normal user. I need to run it as super user: #su
PostPosted: Sat Apr 21, 2018 6:38 am    Post subject: Reply with quote
If I recall, this is just a path issue - it's not on the search path unless you are a superuser...
blakespot
PostPosted: Mon Apr 23, 2018 6:51 am    Post subject: Reply with quote
ping 10.0.2.2
As root I can, indeed, ping 10.0.2.2 -- getting successful ping returns. I can't nslookup anything -- just stalls. Any ideas from here? Thanks.
bp
:::My NeXTs:
PostPosted: Mon Apr 23, 2018 6:56 am    Post subject: Reply with quote
ping 10.0.2.2
bp
what is your /etc/resolv.conf
I'd try the following:
10.0.2.3
this should have slirp intercept and ask the OS on your behalf...
8.8.8.8
the google....
1.1.1.1
1.0.0.1 the new cloudflare ones...
also check your route table..
netstat -nr
make sure your gateway is set to 10.0.2.2
blakespot
PostPosted: Mon Apr 23, 2018 7:29 am    Post subject: Reply with quote
10.0.2.3
8.8.8.8
the google....
1.1.1.1
netstat -nr
I can ping and get returns on 10.0.2.3 but none of the other IPs you mention -- 100% packet loss there. My /etc/resolv.conf is the one following line:
nameserver 10.0.2.3
And my netstat -nr output is:
Thanks.
bp
:::My NeXTs:
PostPosted: Mon Apr 23, 2018 7:34 am    Post subject: Reply with quote
Yep you can only ping 10.0.2.2
Try nslookup
nslookup
> server 1.1.1.1
Default server: 1.1.1.1
Address: 1.1.1.1#53
> www.google.com
Server:         1.1.1.1
Address:        1.1.1.1#53
Non-authoritative answer:
Address: 74.125.201.99
Address: 74.125.201.103
Address: 74.125.201.104
Address: 74.125.201.105
Address: 74.125.201.106
Address: 74.125.201.147
Try all the servers... See if any of this resolves...
Try telnetting to 71.95.196.34
blakespot
PostPosted: Mon Apr 23, 2018 7:41 am    Post subject: Reply with quote
nslookup just stalls pointing at 1.1.1.1 or 1.0.0.1, etc. Telnet to the .34 IP just stalls.
bp
:::My NeXTs:
PostPosted: Mon Apr 23, 2018 7:50 am    Post subject: Reply with quote
I'm not sure.. I'm stuck with only my Android phone and an ancient g4 MacBook at the moment.... So I can't really do anything windows like.
Did you boot with the Ethernet connected?
I find it works best with it unconnected at the ROM, and to enable it after the kernel starts to look initialize
blakespot
PostPosted: Mon Apr 23, 2018 7:59 am    Post subject: Reply with quote
Trying it running as Administrator. I don't do much with Windows, myself, but game. I just couldn't find Previous 2.x on macOS. Do you happen to know where it can be had, precompiled? Thanks.
bp
:::My NeXTs:
PostPosted: Mon Apr 23, 2018 8:02 am    Post subject: Reply with quote
Admin privileges shouldn't matter at all when it comes to slirp...
What version of Windows was it anyway?
Cmake hides everything so I really have no idea if it's doing anything strange while building...
blakespot
PostPosted: Mon Apr 23, 2018 8:05 am    Post subject: Reply with quote
A recent version (if not very latest update) of Windows 10 Pro 64-bit.
bp
:::My NeXTs:
blakespot
PostPosted: Tue Apr 24, 2018 8:40 am    Post subject: Reply with quote
I've tried only enabling Ethernet in Pervious options at different points in the boot sequence and nothing is working. Have you heard of others running Previous 2, Windows 10 Pro 64 having networking work?
Frustrating.
bp
:::My NeXTs:
