Use other "greyscale" monitors with mono systems?
Goto page 1, 2, 3  Next
PostPosted: Fri Nov 03, 2006 9:20 am    Post subject: Use other "greyscale" monitors with mono systems? Reply with quote
Has anyone been able to use other greyscale monitors in place of the next ones on the mono systems. I am not talking about a color vga monitor, but a dedicated greyscale monitor. The reason I ask is that I have a couple of pixelink xds120 greyscale monitors in storage, and I know others like cornerstone created monitors like this. I cant find any specs for it on google, but does anyone think this might be something that could work?
Will post more info on monitors when I can dig around and find them.
NeXTCube, NeXTStation mono, Color, & TurboColor. SGI O2-1600SW, Indigo2, VW320/540, Sparc 5-10-20, HP-712/80
kenjay
PostPosted: Fri Nov 03, 2006 3:53 pm    Post subject: Reply with quote
I have been "studying" this subject for years.
NOTHING ELSE will work correctly Exclamation Exclamation Exclamation
blackcube
PostPosted: Fri Nov 03, 2006 5:21 pm    Post subject: Reply with quote
Same here. I have been considering looking for a source for the CRT tubes used in the N4000a monitors. I had sourced them several years ago but have misplaced the notes. It seems like it was a company in the northern US that priced them in single lots at around $85. As I recall it was a Toshiba tube. Maybe I should crack one open and see if I can find a part number for the tube.
12 NeXTs, uncounted others
I was afraid of something like that.
Was it someone in here who said he had got a sort of picture on a color crt by sending the gray signal to all the color pins on a vga connector. May have been somewhere else, as I have read quite a lot lately, and it all starts turning to mush in my head.
blackcube
PostPosted: Fri Nov 03, 2006 5:35 pm    Post subject: Reply with quote
That was mentioned on usenet and on the old forum but no one to my knowledge has got past the ghosting problem with a VGA monitor.
PostPosted: Fri Nov 03, 2006 5:50 pm    Post subject: Reply with quote
How bad is the ghosting? I guess it is too annoying to use, or people in here would be using it.
blackcube
PostPosted: Fri Nov 03, 2006 6:21 pm    Post subject: Reply with quote
I've never see it myself, just read about it. I have 4-5 good clear bright monitors so at the moment, it's not an issue with me. I have considered installing the kill switch from usenet to allow me to run my Cube 24/7 but conserve monitor life.
PostPosted: Sat Nov 04, 2006 12:17 am    Post subject: Reply with quote
I would guess that the ghosting problem is because the signal is coming down one line and then splitting into 3, thus if blue arrived at a different time than red and/or green then you would get ghosting. Considering how fast a monitor scans it would only need to be the smallest fraction of a second and you would get the problem. Think of it like FM multipath distortion. Maybe also red is poisoning (kind of like a feedback) green, and blue and vice versa as they are all connected together, perhaps using a few diodes would prevent signals feeding back into each other.
When I was on my exploits into trying to get my TFT working with NeXT I recall I read a monitor service manual, maybe a DEC one that said if you want to connect a mono monitor to a color computer you connect green only, reverse that and you connect mono out to green in on a colour monitor. Perhaps this also explains why we have SOG on not sync on red or blue?. I don't have mono so I can't test it but I'd think it would be worth experimenting. As far as I know so far people have tried to interface to color monitors. Should it not be a lot easier trying with a mono monitor?
blackcube
PostPosted: Sat Nov 04, 2006 7:25 am    Post subject: Reply with quote
brams wrote:
I would guess that the ghosting problem is becuase 1 signal is coming one line and then joining into 3, thus if blue arrived at a different time than red and/or green then you would get ghosting. Considering how fast a monitor scans it would only need to be the smallest fraction of a second and you would get the problem. Think of it like FM multipath distortion. Maybe also red is poisoning (kind of like a feedback) green, and blue and vice versa as they are all connected together, perhaps using a few diodes would prevent signales feeding back into each other.
When I was on my exploits into trying to get my TFT working with NeXT I recall I read a monitor service manual maybe a DEC one that said if you want to connect a mono monitor to a color computer you connect green only, reverse that and you connect mono out to green in on a colour monitor. Perhaps this also explains why we have SOG on not sync on red or blue?. I don't have mono so I can't test it. But I'd think it would be worth experimenting. As far as I know so far people have tried to interface to color monitors. Should it not be a lot easier trying with a mono monitor.
That makes a lot of sense to me. I should look for a monochrome VGa monitor to try it on.
PostPosted: Sat Nov 04, 2006 9:16 am    Post subject: Reply with quote
From what I have found, one of the "features" of the greyscale monitors is that they usually have a higher dpi than a standard color vga monitor. I found some docs for the pixelink I have, and it touts that it is 120dpi high resolution. I also remember cornerstone touting the "high resolution" of their gs displays as well. I assume that the NeXT monitor would be similar? I do not know how monitors work in detail, but could it be that the color VGA monitor can not properly display/focus the higher res signal from the nextstation.
PostPosted: Sat Nov 04, 2006 8:36 pm    Post subject: Reply with quote
That would make the image all green then, right? Might be kind of funky to do it that way, sort of like an old mainframe terminal display. I would prefer all blue if I had the choice.
PostPosted: Sat Nov 04, 2006 11:51 pm    Post subject: Reply with quote
If you connected the mono out to green I assume it might be I've assumed a lot in the past and been wrong, so for what it would take to try it which is not a lot, I'd be up for experimenting, especially today (Sunday) as I'm a bit bored and eBay usually beckons when I'm bored........ The other way around might work OK outputting green into a mono monitor but that not what is needed.
I'd get an old high res mono monitor and experiment with that, not sure what might be suitable, maybe a DEC one?
I personally feel that as all wires are connected to each other R G & B on the monitor to the mono signal that they are feeding back into each other, for what it would cost, get a handful of small diodes, put one on each wire and try it.
nextime
PostPosted: Sat Nov 11, 2006 12:27 pm    Post subject: Reply with quote
I saw a non NeXT display used with the Mono NeXT.
If I remember this was a prototye and never made it beyond that.
I do not have any additional information.
This was in the early 90's.
w2510a
PostPosted: Mon Nov 20, 2006 12:09 am    Post subject: Non-Next Monitor on NextStation Mono Reply with quote
Hi all,
I have successfully connected a plain VGA multisync monitor (17 inches Olivetti brand with Sony CRT) to my NextStation Mono via BNC connectors. It works fine, no ghost images. As soon as I find time, I will provide a few pictures. Next step will be to connect a TFT display. I have an old 16-inch IBM display (IBM 9516-B23 TFT), which I already use for SUN (SparcStation 20), IBM (RS 6000/7011-44), SGI (Indy 4600, Indy 5000), DEC (VAXstation 4000-90) and Commodore (Amiga 2000) computers. It is not a high quality screen, viewing angle and brightness are quite limited. However, it does Sync-On-Green and works with virtually all machines that I could find so far.
Unfortunately, a problem remains - maybe somebody can help:
Originally, mouse and keyboard are connected to the Next monitor. As I do not have the Next monitor, I have no input devices for my NextStation Mono! On Color Stations this should not be a problem because input devices are connected via Soundbox anyway. Maybe I will try to connect a Soundbox with my Mono Station. Does anybody have an experience with that?
Best regards,
Günther
PostPosted: Mon Nov 20, 2006 8:06 am    Post subject: Reply with quote
w2510a, what kind of adapter did you use? Something off the shelf, or that you had to fabricate yourself. More info please, and pics would be great.
Page 1 of 3
Powered by phpBB © 2001, 2005 phpBB Group
