Dead pram battery? Try this.
PostPosted: Sun Jan 28, 2007 10:56 pm    Post subject: Dead pram battery? Try this. Reply with quote
Okay, I don't know of this is already commonly known or something new.
Anyways, my quadra 660AV lost it's pram battery years ago.
Today I was really bored and my eyes caught on my quadra which was sitting on my desk doing nothing.
Using two AA batteries, tin foil, steel wool, copper wire and duct tape I successfully managed to make a crude pram battery that works and preserves the pram when the system is off.
I'll make this offical once I find how long the battery lasts.
PostPosted: Tue Jan 30, 2007 5:46 pm    Post subject: Reply with quote
NOTE:
Be positive your leads will not come loose.
A quadra 660AV is real annoying to reconfigure when you are using monitor settings stored in pram.
PostPosted: Wed Jan 31, 2007 10:21 pm    Post subject: Reply with quote
It might be worth the few Dollars, Euro, Bucks, whatever to invest in a LS-14250 3.6v lithium battery..
This battery will also work in a NeXT. There are equivalent part numbers in any battery cross-reference guide.
Might be cheaper than replacing the 660..
Are you running A/UX on it?
PostPosted: Thu Feb 01, 2007 11:09 am    Post subject: Reply with quote
nope. no A/UX Crying or Very sad
I have a tape copy for a IIx or IIfx but I don't have either system and the tape drive is still being fitted for a new roller after the last one turned to sludge,
Quote:
PostPosted: Wed Jan 31, 2007 11:21 pm Post subject:
Some people (like me) are poor folk and have a huge supply of unused AA batteries. Why buy when you can make to with what you have? Laughing
applefreak
PostPosted: Fri Mar 02, 2007 5:45 pm    Post subject: Reply with quote
A/UX
http://www.aux-penelope.com/downloads.htm
early mac systems
http://members.tripod.com/elfen_magix/VMSsoftware.html
http://www.info.apple.com/support/oldersoftwarelist.html
http://download.info.apple.com/Apple_Support_Area/Apple_Software_Updates/English-North_American/Macintosh/System/
applefreak
PostPosted: Fri Mar 02, 2007 5:54 pm    Post subject: Reply with quote
monitor settings of mac's are always stored in pram
(re)install a system on a quadra 660AV is as easy it can be using a external SCSI HD with the appropriate system on it
PostPosted: Fri Mar 02, 2007 8:36 pm    Post subject: Reply with quote
Thanks for the links but I am going way back to 1.1 and I would prefer to get the genuine media and books (I got in big trouble for distributing older copies of IRIX because I thought that they were discontinued and were safe to copy).
As for the quadra...
It's at the bottom of a stack of systems and it's monitor is my camera monitor. When the pram goes, I have to pull a whole bunch of systems to get the cover off and then find an apple monitor so I can reconfigure the video output again.
PostPosted: Sun May 13, 2007 10:03 am    Post subject: Reply with quote
Many months later and the batteries are still keeping the system alive,
I got a mac II in a few weeks ago with a dead battery (so dead the polarity had reversed) and thus could not turn on. Two short alligator leads and two AA batteries was all that was needed to jumpstart the system.
da9000
PostPosted: Mon May 14, 2007 2:06 am    Post subject: Reply with quote
applefreak wrote:
A/UX
Thanks so much for the links Applefreak!! Now, one day, my old Macs can try something new :)
@Pentium:
I've got to see the jerry-rig battery contraption you made! Smile Got any photos?
PostPosted: Sat May 19, 2007 6:32 pm    Post subject: Reply with quote
Photos?
Okay.
^Two AA batteries connected together with duct tape and tinfoil and wires marked for their respective polarity.
^Battery installed in an LC III. Just wrap the both wires coming from your battery around their respective battery terminals on the case. Don't make it loose or shaking the case will cuase a flakey connection.
^ If you are in a rush and a permanant battery is not needed, using two alligator lines and two AA batteries, you can jumpstart those macs who need a battery to just turn on. Very Happy
da9000
PostPosted: Sat May 19, 2007 8:11 pm    Post subject: Reply with quote
Hehehe, cool Very Happy Although I hate the silver tape. I prefer using masking tape for my jerry-riggin' :)
Maybe use some superglue/epoxy to make it more rigid? :p
PostPosted: Sat May 19, 2007 8:53 pm    Post subject: Reply with quote
Did you just imply you dislike duct tape?
FYI, Duct tape is the second most used staple (redbull being first to aid in those long nights) in the home network world. There is not many computers in my house that don't have duct tape somewhere on them. Laughing
da9000
PostPosted: Mon May 21, 2007 4:46 am    Post subject: Reply with quote
Yes, I did!
It's crappy, and here's why:
Even though very strong and with great tensile margins, it's hard to cut without a sharp instrument, and when you're jerry-rigging you most likely don't have one on you! While with masking tape, you just pull on one side and rip it. It usually rips cleanly with a straight-edge, as well. Sure, you can use your teeth, but one day you'll probably have one stuck to the duct tape itself :)
Yet another reason is that as it ages, the adhesive becomes a sticky runny guey substance and it's really hard to get off of things, and worse, once you touch it you become all sticky yourself. Too many cables exhibit this "disease" :)
Some masking tapes have this problem too, but not all.
Jenne
PostPosted: Mon May 21, 2007 5:08 am    Post subject: Reply with quote
da9000 wrote:
...it's hard to cut without a sharp instrument, and when you're jerry-rigging you most likely don't have one on you!
This is why I always have one of these around:
http://www.victorinox.com/index.cfm?site=victorinox.ch&page=350&lang=E
And in case I'm needed as life supporter I always have one of these around:
http://www.victorinox.com/index.cfm?site=victorinox.ch&page=491&lang=E
da9000 wrote:
Yet another reason is that as it ages, the adhesive becomes a sticky runny guey substance and it's really hard to get off of things, and worse, once you touch it you become all sticky yourself. Too many cables exhibit this "disease" Smile
Absolutly true. I always use other materials if possible to make constructions like these and in case there is not enough space inside a computer I tend to use these hot glue sticks... Risky business sometimes...
J
da9000
PostPosted: Mon May 21, 2007 5:17 am    Post subject: Reply with quote
WOW! Those are impressive, especially the "life support" one Very Happy LOL!
I've been stuck with a dinky one from the 80's, and the problem is that I _always_ forget to have it on me/with me :/
Yeah, I'm a hot glue guy since the day I discovered them Smile Much much cleaner for these kinds of jobs, and even though it's hot, I wouldn't call it risky, unless you try to use it on your eyes or something Very Happy
