NeXT DSP Memory Expansion Module
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
PostPosted: Wed Apr 19, 2017 2:42 am    Post subject: Reply with quote
Looking at the source code of dsp_cpu.c: there is a DSP memory map assumed (for Atari's Falcon). I'm not sure if this is valid for NeXT's 96K expansion. Have to check the mapping/wiring we found.
The large DSP expansion module from the San Francisco State University would definitely provide a different memory layout having just 3 64K chunks of non mirrored / non overlayed program, data x and data y memory.
PostPosted: Wed Apr 19, 2017 3:11 am    Post subject: Reply with quote
The memory map at the top of dsp_cpu.c was modified to reflect NeXT's layout for a 24k module. But as noted in the file it is mostly a guess. Anyway it seems to work without problems with all DSP software I tested so far (including NeXT diagnostics). Memory layout for 96k is similar: below 0x8000 overlapping 32k dsp-words. above 0x8000 separate 16k data spaces (mirrored once) overlapping with 32k program space.
As you noted the large memory module will most likely fill all space with non-mirrored and non-overlapping memory. That might in fact break some software, if it relies on overlapping.
PostPosted: Wed Apr 19, 2017 3:58 am    Post subject: Reply with quote
Please have a look at the address mapping SlateBlue and me found at https://docs.google.com/spreadsheets/d/1IEQZNNyqNDBm2rji7DHeYrpfK_TktUw3WzUsdI8wsJM/edit?usp=sharing, tab "Address mapping". I cannot bring your comments on the 96K module in line with what we found.
Main findings for me:
SRAMs together provide one 24-bit DSP word (3x 8 bit).
Program memory select (_DSPPS) and data memory select (_DSPDS) are not used by the module. i.e. there seems to be no distinction between program and data memory which means they would overlap.
The multiplexer is only used to generate the A14 address line of the SRAMs like this:
Inputs: DSPA14 is I0b, DSPXY is I1b
DSPA15 selects between both
Output _Zb (output is inverted) goes to A14 of SRAMs
That of course leads to a rather strange mapping of logical to physical memory you can see in tab "Address mapping" of our spreadsheet. I still have some doubts this is true but that is what we found so far.
PostPosted: Wed Apr 19, 2017 4:20 am    Post subject: Reply with quote
Which software can be used for testing apart from diagnostics?
PostPosted: Wed Apr 19, 2017 5:10 am    Post subject: Reply with quote
I'm afraid I don't understand this. But does that mean it is probably as simple as just mapping 8k DSP-words overlapping and repeating throughout the entire address space (of course except internal ROM, I/O, etc)? That would match my mapping below 0x8000. Then mapping above this value is probably wrong and this memory range was not used by the software I tested.
For example Mandelbrot and ScorePlayer demos (NeXTstep 1.x and 2.x) are heavily using DSP. But in this case it might be more useful to write a custom program (unfortunately I can't do that). One could then write for example to X data memory at 0xX800 and see if the data can be read at Y data memory 0xX800 and P memory at 0xX800 and at X data memory 0x(X+2)800 (repeat with X = 0 through X = F).
PostPosted: Wed Apr 19, 2017 5:25 am    Post subject: Reply with quote
I'll try to come up with a mapping description similar to the one in dsp_cpu.c.
Can you answer these questions?
How much internal memory does the DSP56001 have and how is it mapped into the address space? Is this the same address space that also covers the external expansion memory?
How does the DSP56001 know the external memory configuration? Is it configured by some bootstrap code? Or maybe it is not configured and the DSP programs have to find out / know?
PostPosted: Wed Apr 19, 2017 6:07 am    Post subject: Reply with quote
Stupid question, as I am not knowing what a multiplexer does, but isn't this (quote from the spread sheet) "So either SIMM connector's DSPA14 or DSPXY signal is routed to A14 of the SRAM chips depending on DSPA15" almost exactly doing what is shown in my drawing in dsp_cpu.c:
Below 0x8000 (DSPA15 is 0): Route DSPA14 to A14.
Above 0x7FFF (DSPA15 is 1): Route DSPXY to A14 and thus split physical DSP memory into two separate pieces of same size depending on selected data memory space (X or Y).
Then in my drawing only P above 0x7FFF is wrong, because only X and Y matters and P does either go to X or Y block depending on DSPXY.
Update: If DSPDS would be wired in a way, that DSPA14 is always routed to A14, if P memory is selected, it would match my drawing 100%, wouldn't it?
   The memory map is configured as follows :
   0x0000 to 0x7fff:
   Program space P and data spaces X and Y are contiguous
   8k dsp Word blocks. They overlap in physical memory.
   0x8000 to 0xffff:
   X and Y data spaces are physically separate 4k dsp Word
   blocks. Program space P is a contiguous 8k dsp Word block
   and phyically overlaps X and Y data space.
   Y: memory is mapped at address $8000 in P memory
   X: memory is mapped at address $9000 in P memory
                 X:             Y:             P:
   $ffff  |--------------+--------------+--------------|
          |   Int. I/O   |   Ext. I/O   |              |
   $ffc0  |--------------+--------------+              |
          |   Mirror(8)  |   Mirror(8)  |   Mirror(4)  |
   $A000  |              |              |--------------|
          |              |              |      8k      |
   $9000  |--------------+--------------|   External   |
          |      4k      |      4k      |     RAM      |
          |   External   |   External   |              |
          |     RAM      |     RAM      |              |
   $8000  |--------------+--------------+--------------|
          |   Mirror(4)  |   Mirror(4)  |   Mirror(4)  |
   $2000  |--------------+--------------+--------------|
          |      8k      |      8k      |      8k      |
          |   External   |   External   |   External   |
          |     RAM      |     RAM      |     RAM      |
   $0200  |--------------+--------------+--------------|
          | Log table or | Sin table or |              |
          | external mem | external mem |   Internal   |
   $0100  |--------------+--------------+    program   |
          |  Internal X  |  Internal Y  |    memory    |
          |    memory    |    memory    |              |
   $0000  |--------------+--------------+--------------|
My drawing answers this question. It has 256 DSP-words internal X memory, 256 DSP-words internal Y memory and 512 DSP-words internal P-memory. Furthermore it has internal constant ROMs, 256 DSP-words each, in X and Y memory space. I/O registers are mapped at the top of X and Y memory spaces. The internal memory and I/O memory partially cover (overlap with) external memory.
The DSP itself does not know how much external memory it has. Software has to find it out. NeXT does this by writing to some location and then check if/where the data can be read (e.g. write to 0x0800 and finding data at 0x2800 means 24kB memory installed).
PostPosted: Wed Apr 19, 2017 6:52 am    Post subject: Reply with quote
We are thinking in the same direction, but...
The multiplexer inverts its selected input, which means the physical blocks are mapped the other way round.
DSPXY is always set to 1 if program memory is accessed (at least I read this).
Address bits 0 - 13 are routed straight through to the SRAMs, i.e. the interesting stuff is happening at 16K blocks. So my picture, which tries to show which physical memory is mapped to which logical memory, looks like this:
Given:
SRAMs
Physical Base Address   16K block name
$4000                   S2
$0000                   S1
This would be the mapping (not showing the overlay with internal memory):
DSP56001
Logical Base Address   X   Y   P
$C000                  S1  S2  S1
$8000                  S1  S2  S1
$4000                  S1  S1  S1
$0000                  S2  S2  S2
Does this make sense?
PostPosted: Wed Apr 19, 2017 8:46 am    Post subject: Reply with quote
My above drawing shows the map for 8k dsp-words while yours is for 32k dsp-words. I think it mostly matches (although i don't invert the input, which should not matter if it is same for reading and writing; X block being S2 seems to be correct in my code). There is only one difference: In my table P memory is treated the same no matter if addressed from below or above 0x8000. Are you sure DSPDS signal is unused? My table translated to 32k and your format looks like this (inversion difference ignored):
SRAMs
Physiacal Base Address   16k block name
$4000                    S2
$0000                    S1
DSP56001
$C000                  S1  S2  S1
$8000                  S1  S2  S2
$4000                  S1  S1  S1
$0000                  S2  S2  S2
And for 8k dsp-words:
SRAMs
Physiacal Base Address   4k block name
$1000                    S2
$0000                    S1
DSP56001
$F000                  S1  S2  S1
$E000                  S1  S2  S2
$D000                  S1  S2  S1
$C000                  S1  S2  S2
$B000                  S1  S2  S1
$A000                  S1  S2  S2
$9000                  S1  S2  S1
$8000                  S1  S2  S2
$7000                  S1  S1  S1
$6000                  S2  S2  S2
$5000                  S1  S1  S1
$4000                  S2  S2  S2
$3000                  S1  S1  S1
$2000                  S2  S2  S2
$1000                  S1  S1  S1
$0000                  S2  S2  S2
SlateBlue
PostPosted: Wed Apr 19, 2017 9:06 am    Post subject: Reply with quote
I guess we're not certain DSPDS isn't used, but I find no continuity from SIMM pin 42 to the multiplexer, nor to the SRAMs. All questions seem to lead back to this, so I can try checking again.
PostPosted: Wed Apr 19, 2017 11:30 am    Post subject: Reply with quote
I'm struggling with the way you use "32K" respectively "8K" DSP words.
My table's granularity is 16K (0x4000 = 16384), not 32K.
Your table's granularity is 4K (0x1000 = 4096), not 8K.
Can you clarify?
PostPosted: Wed Apr 19, 2017 11:33 am    Post subject: Reply with quote
The problem is: where should it go to? The two inputs of one "channel" of the multiplexer are used. Cascading them does not make sense. And the SRAM only have one Enable input which is also used (connected to _DSPRMEN, SIMM pin 60).
PostPosted: Wed Apr 19, 2017 11:44 am    Post subject: Reply with quote
Have to take that back. One could route the output of the A14/DSPXY multiplexing through another multiplexing and let _DSPDS decide what the final result is (either the output of the first stage or something else, e.g. A14 again.)
PostPosted: Wed Apr 19, 2017 12:23 pm    Post subject: Reply with quote
Can you clarify?
My table in dsp_cpu.c shows the layout of the standard 24 kB (8k dsp-words) module while your table shows the layout of the 96 kB (32k dsp-words) expansion module. Because A14 is derived from different sources 8k is logically split into two 4k blocks and 32k is split into two 16k blocks.
That is exactly what i am suspecting (in pseudo-code, inversion ignored):
if (DSPA15) {
    if (DSPDS) {
        A14 = DSPA14;
    } else {
        A14 = DSPXY;
} else {
    A14 = DSPA14;
or with same result:
if (DSPDS) {
    A14 = DSPA14;
} else {
    if (DSPA15) {
        A14 = DSPA14;
    } else {
        A14 = DSPXY
I can't confirm it, because i have no way to test (know-how missing and no NeXT hardware here).
PostPosted: Wed Apr 19, 2017 2:02 pm    Post subject: Reply with quote
SlateBlue checked all outputs of the multiplexer (_Zx) and apart from _Zb (which yields the selection via DSPA15) all other outputs seemed to be open / floating / going nowhere. I guess we can give that another try.
Page 6 of 9
