Porting Tips
Mike_H
PostPosted: Thu Jan 26, 2006 12:26 am    Post subject: Porting Tips Reply with quote
NEXTSTEP:
http://www.drolls.de/NeXT/Porting-General.html
OPENSTEP:
http://www.math.unl.edu/~rdieter1/OpenStep/Developer/PortingTips/
Mike
da9000
PostPosted: Sat Dec 09, 2006 4:22 am    Post subject: Re: Porting Tips Reply with quote
The 1st one asks for login :(
Haven't tested the 2nd as I don't have Openstep :/
Mike_H
PostPosted: Wed Dec 13, 2006 12:06 pm    Post subject: Re: Porting Tips Reply with quote
da9000 wrote:
The 1st one asks for login Sad
I wish I had made a copy of the web page, as it appears that their robots.txt file prohibits bots from archiving the NeXT section. Sad
Mike
PostPosted: Fri Jun 29, 2007 10:49 am    Post subject: Re: Porting Tips Reply with quote
I contacted the owner of the site and asked if I could get a copy of the pages to host here. I received a response from Sven Droll who kindly forwarded two of the main pages. Iím in contact with him now to retrieve any remaining pages. He also mentioned that he used to be one of the admins for the Peanuts Archive. :)
http://www.nextcomputers.org/NeXTfiles/Docs/Developer/Porting_Tips/
http://www.nextcomputers.org/NeXTfiles/Docs/Developer/Porting_Functions/
da9000
PostPosted: Thu Jul 12, 2007 2:17 am    Post subject: Reply with quote
Nice one Nitro! I'm sure it'll be handy to many.
Noth
PostPosted: Sat Oct 03, 2009 10:08 am    Post subject: Reply with quote
Hi there,
I'm trying to update my NeXT Cube running NS3.3 to be able to port some software over. I've already got gcc 2.7.2.3 installed along with its libs, but even basic stuff like grep 2.4.2 won't compile cleanly. Is there a list of all the updated tools I need to be able to port software for NS3.3 (plus how do you cross compile to create quadfat binaries?).
Cheers,
Noth
PostPosted: Sat Oct 03, 2009 12:31 pm    Post subject: Reply with quote
Noth wrote:
Hi there,
Cheers,
Noth
I build quadfat binaries with the shipped CC
cc -arch i386 -arch m68k -arch sparc -arch hppa
I suppose if you build enough cross compilers it'll do the job.....? Just save the native 'gcc' binary...
I also build bison 1.25 /flex 2.5.4a/gawk 3.022/make 3.75 & bash 2.01
With those I have some good luck building things.
iDork
PostPosted: Sat Oct 03, 2009 12:46 pm    Post subject: Reply with quote
There was a thread about GCC 2.95.3 here:
http://www.nextcomputers.org/forums/viewtopic.php?t=830
with links to 68k binaries. If I my color turbo slab still works, I might give them a try. I remember reading the instructions on the linked page, but I couldn't figure out how to build it for x86.
Does anyone have pre-built x86 binaries?
NS TurboColor, SparcStation 5, Ultra 10, Octane SSI, HP 9000 C110, AlphaStation 200, Apple IIgs|IIe|IIc, Amiga 500+|600|1200, Commodore 64|128
PostPosted: Sat Oct 03, 2009 12:55 pm    Post subject: Reply with quote
I must have forgotten about the whole thing....
At the moment I'm being tripped up by 'dirname'....
PostPosted: Sat Oct 03, 2009 1:29 pm    Post subject: Reply with quote
I lifted the dirname from opensolaris:
http://src.opensolaris.org/source/xref/onnv/onnv-gate/usr/src/cmd/dirname/dirname.c
And linked it against textutils-1.19's libintl.
I know. what a hack. Sad
configure ran, and it's compiling stuff now.
PostPosted: Sat Oct 03, 2009 1:52 pm    Post subject: Reply with quote
Ok, here we go "hot off the compiler"...
I've tested unzip to work.......
Anyways the object & exes are here:
http://dl.getdropbox.com/u/1694005/gcc-2.95.3-compile.tar.bz2
You'll also need the source code:
http://ftp.gnu.org/pub/gnu/gcc/gcc-2.95.3.tar.gz
*NOTE that this is just a compiled set, you'll probably still need some kind of gnu make ( make 3.75 works for me),and I would imagine all the nextstep dev tools.. I wouldn't imagine what this would do if you didn't have the libs in place...
You'll need to extract the source into a parallel directory, and run
gmake install
from the gcc-2.95.3-compile directory.
I guess you can manually place stuff...
/usr/local/lib/gcc-lib/i386-next-nextstep3/2.95.3
bash-2.01# ls
SYSCALLS.c.X  cc1plus       crtbegin.o    include       libobjc.a
cc1           collect2      crtend.o      libg2c.a      libstdc++.a
cc1obj        cpp0          f771          libgcc.a      specs
Anyways, it built somewhat cleanly, but you have to fix the one file as mentioned here: http://www.savarese.org/patches/gcc.html
-- edit
I've even tested the F77 compiler... and it works!
bash-2.01# time g77 *.f -o xx
np.f: In function `synmch':
np.f:683: warning:
   200       CALL UNPACK(J,NEWJ)
Reference to unimplemented intrinsic `UNPACK' at (^) (assumed EXTERNAL)
real    0m3.650s
user    0m2.160s
sys     0m0.250s
bash-2.01# file xx
xx:     Mach-O executable (for architecture i386)
bash-2.01#
Much to my amazement, as it's documentation said G77 didn't work at all.. I guess there has been a LOT of improvements along the way...
bash-2.01# ./xx
 Welcome to Dungeon.                    This version created 30-AUG-90.
 You are in an open field west of a big white house with a boarded
 front door.
 There is a small mailbox here.
 >history
 Revision history:
 30-AUG-90  Portable non-DEC version
 18-JUL-80  Transportable data base file (V2.5A).
 28-FEB-80  Compressed text file (V2.4A).
 15-NOV-79  Bug fixes (V2.3A).
 18-JAN-79  Revised DECUS version (V2.2A).
 10-OCT-78  Puzzle Room (V2.1A).
 10-SEP-78  Endgame (V2.0A).
 10-AUG-78  DECUS version (V1.1B).
 14-JUN-78  Public version with parser (V1.1A).
 4-MAR-78   Debugging version (V1.0A).
--- another edit --
Also don't forget to 'fix' the specs files, or the posix stuff will break.
What is funny, is that the posix exe's are MASSIVE... like 360kb for a null executable....
bash-2.01$ cat x.c
void main(void){}
bash-2.01$ cc -posix x.c -o x;ls -l x
-rwxr-xr-x  1 me         87292 Oct  3 17:26 x
bash-2.01$ gcc -posix x.c -o x;ls -l x
x.c: In function `main':
x.c:1: warning: return type of `main' is not `int'
-rwxr-xr-x  1 me        364412 Oct  3 17:26 x
iDork
PostPosted: Sat Oct 03, 2009 10:41 pm    Post subject: Reply with quote
Thanks, I'll give it a try.
Alex
Noth
PostPosted: Sun Oct 04, 2009 4:19 am    Post subject: Reply with quote
Thanks for the tips. So far I've been able to update the toolchain to the suggested level, but I still can't compile a basic command such as grep! I've been hunting high and low for a m68k binary but I can't find it on any mirror at [url]nextstuff.info/mirror/[/url] or on this site's file repository. And grep is required for a shedload of compiles to work. I even get circular dependencies compiling the latest 2.5.3 grep asking for grep! I'm mainly trying to get the 2.4.* to work, but that fails... maybe I need gmake ? Which isn't easy to find either as a binary....
PostPosted: Sun Oct 04, 2009 5:26 am    Post subject: Reply with quote
gmake 3.75 should build with nothing....
I just wish I could figure out a 'nice' way to build ncurses as a quad fat library as it builds a .a file, then keeps adding to it, but you can't do that with quadfat libs... Neutral
I'll probably just build out some stuff that I can as quad fat, basic stuff... minus gcc as I *think* Id have to do some intense moving around as a cross compiler... I'm not sure how next did it's config back then.
Version 2.0 of GNU's grep built with cc with no issues... 2.4 seemed to build fine as well, it configured fine for gcc and I just altered the makefile to use cc & include all the quad fat stuff, and it built. I've included version 2.0 & 2.4 in the list of stuff....
-- edit
I've built a few things as quad fat...
http://dl.getdropbox.com/u/1694005/nextstep/bison-bzip2-flex-gawk-gmake-unzip.tar.gz
http://dl.getdropbox.com/u/1694005/nextstep/bash.gz
http://dl.getdropbox.com/u/1694005/nextstep/qgrep.gz
http://dl.getdropbox.com/u/1694005/nextstep/qgrep24.gz
The name should be pretty self explanatory... and gnutar on nextstep should be able to handle this file. I've named all these exe's as Q???? ie qbzip2 incase you have an existing one... Or if you want to lipo it out.
I should also note that gmake isn't the most solid program out there, and it cannot build itself... but it can build all kinds of other things.. it's really odd but I've not spent that much time worrying about it.
Noth
PostPosted: Sun Oct 04, 2009 9:04 am    Post subject: Reply with quote
Thanks a lot, I'll get these as soon as the server lets me get them. Hopefully that will do the trick.
