Next Dimension capacitors
Started by NeXTnewbe, February 13, 2019, 01:58:31 AM
NeXTnewbe
Hi
does anyone know the replacement parts for the next dimension capacitors, please?
Thank you
krazycat
I also agree with NeXTnewbe's request, I think my NeXTdimension needs new capacitors because it doesn't turn on anymore... can someone help me?
NeXTnewbe
Quote from: krazycat on April 25, 2019, 09:19:53 AMI also agree with NeXTnewbe's request, I think my NeXTdimension needs new capacitors because it doesn't turn on anymore... can someone help me?
Hi Krazycat
I found this
http://www.asterontech.com/Asterontech/dimension_restore.htm
Hello NeXT  Community: Is it OK to use the http://www.asterontech.com/Asterontech/dimension_restore.htm
Is it OK to use the
47 uF 16 VDC 20%      85C   1206 - 1.6 x 3.2
   C3216X5R1C476M160AB                   Q6  GREEN
   Ceramic Replacement
instead of
 220 uF 4 VDC  20%      85C 1206 - 1.6 x 3.2 Q7 RED
NeXT Dimension Board (Revision: PN-1508.AD)
Capacitance    Voltage Tolerance Temp Dimensions (mm)
   Part #
   Quantity
   Locations
   Notes
47 uF
   16 VDC
   20%
   85C
   1206 - 1.6 x 3.2
   C3216X5R1C476M160AB
   6
   GREEN
   Ceramic Replacement
220 uF
   25 VDC
   20%    85C    8 x 11.5
   UVR1E221MPD
   1
   Yellow
220 uF
   4 VDC
   20%
   85C
   1206 - 1.6 x 3.2
   7
   RED
Total
   14
Best regards Rob Blessin
If your board has the 47uF there instead then yes. I think this is a more common configuration.
crispin
Hey Rob,
Any chance the NeXT Dimensions you sell are recapped?
