Exchange HD from dimension cube to mono
Started by Andreas, December 05, 2007, 11:52:11 AM
i like to put a hd from a dimension cube into a "normal" one. the cube boots up but stays with a grey display, so i assume it tries to initialize the dimension display.
Does anyone know how to set the preferences from the color display to the native one? (booting into singleuser mode ans delete something?)
ericj
Quote from: "Andreas"i like to put a hd from a dimension cube into a "normal" one. the cube boots up but stays with a grey display, so i assume it tries to initialize the dimension display.
Did you try booting using "config=Default"? Although, I've only used this on white box hardware, so I don't know about doing this on black hardware.
Eric
Quote from: "ericj"Did you try booting using "config=Default"?
unfortunatly this is only a option for white hardware, but i have a solution:
after a hard reset (unplug power cord) and after repairing the filesystem the cube is proper running.
rice0067
another way would probably be to install the HDD in the mono slab, boot into single user and just overwrite the config files from /private...
the same way that you reset the root password.
(I don't have a nextstation anymore so I dont remember the exact path.)
ericj
OK, I had a feeling.
Eric
