SCSI2SD version 5.1 Card issue
Started by krazycat, May 28, 2019, 03:40:19 PM
Hello : You should be able to do it in scsi2sd app using the drop down menu and update firmware and pointing it at the 4.8.X firmware file.  If it can still talk to the card  I'm surprised their was no a software fail safe popup panel to prevent 5.2 firmware flashing to 5.1 cards. You may check the codesrc website faq on it as well https://www.codesrc.com/mediawiki/index.php/SCSI2SD_UserManual
