NeXT Cube powers up, 3 secs later powers down
Started by daniel.dlds, July 08, 2022, 04:55:38 AM
daniel.dlds
I got the attached image from the ATX conversion page :
Which PINS of the left most column should I short ? When doing this, I think that I should put 3V on the pins of the column to the right ?
PS: if image does not appear it is at : https://ibb.co/1QD9Y3b
Thanks for any help,
Regards
The RTC is next to the battery and a small surface mount crystal. To check the power supply rails you also may need a load across the -12v rail to keep it powered. Otherwise, yes just hook the battery to the marked input.
daniel.dlds
Quote from: barcher174 on October 16, 2022, 01:45:07 PMThe RTC is next to the battery and a small surface mount crystal. To check the power supply rails you also may need a load across the -12v rail to keep it powered. Otherwise, yes just hook the battery to the marked input.
So to power on the power supply I should (in sequence) ? :
- apply a load between a pin on the 12V and GND
- supply the 3V to the input marked -3V momentarily (I suppose this is the signal sent from the battery when the power button in pressed)
Regards
1) -12v to GND ~330ohm
2) You need to keep the 3V applied I think.
daniel.dlds
I made a small diagram of the connector of the Cube's power supply, the resistor acting as the Load and a bench power supply to turn on the NeXT power supply.
it is here : https://ibb.co/8gRjGj5
There is a question mark on the second wire coming from the power supply (GND or negative, I really don't know which). I think I need to make this connection somewhere because if not, no current will flow into the -3V of the PSU.
Am I right ?
The 330ohm should go from the blue boxed -12v to black boxed GND. The battery should attach from light blue boxed 3v input to black boxed GND.
daniel.dlds
Thanks for you reply.
What is the power rating of the 330 Ohm resistor, that I should use ?
Regards
A big one. Like 5w. Alternatively I use a bulb like this: CBconcept - 10 Bulbs - 12V 5 Watts, AC/DC JC T3 G4 Bi-Pin 5W Halogen Light Bulb, Accent Lighting, Chandelier, Puck Light, Microwave, Range, RV, Landscape Lighting - Designed in CA https://a.co/d/e9Fb0Vd
daniel.dlds
I tried to test the power supply in isolation, by connecting the 12V to a light bulb and the battery across the -3V pins. The power supply didn't turn on. I don't know what I did wrong.
Anyway, I re-installed the PSU in the cube, and powered it on. This time it didn't shutdown after a few seconds. I left it running for about half hour and it stayed on.
Problem is that now the computer shows a grey screen with vertical stripes, and does not boot. It even does not do the system test. It just stays on the grey screen. (link to a photo of the screen : photo)
So I am starting to suspect that there was nothing wrong with the power supply, but with the main board.
How can I continue testing ?
Regards
No easy answers from here. Recap —> RTC chip —> cpu or next asic fault
Hello Daniel: You can also try removing the ram and unplugging the hard drive then powering it on to see if is the main board causing that pattern. I have had that happen with incompatible ram or a bad memory stick or like Brian is saying new caps :)
daniel.dlds
I removed all the RAM disconnected the hard drive (SCSI2SD), but the behaviour is the same.
The board was sold to me recapped. Is it possible that in the space of a year or so a cap may be bad ?
Can you post some high res pics of both sides? Also some close ups around the new caps.
There is a cap missing on the left hand side of pic 1 next to the video ram. Some of the ceramic replacements look questionable. I would redo the work.
