NeXT Cube powers up, 3 secs later powers down
Started by daniel.dlds, July 08, 2022, 04:55:38 AM
daniel.dlds
I don't know how to locate it. Could you post the picture with a drawn circle around the cap ?
In the link I provided check the green circles at the bottom.
daniel.dlds
Back at this. It has been a while. So, do you recommend that I remove the ceramic capacitors and put electrolytic ones, or just do a better job at re-soldering the ones that are already in place ?
Anyway, I am thinking of replacing all of them with the ones listed in the link you pasted.
Any one of them electrolytic or not may have failed.
Ceramics are fine. Just clean up and add the missing one.
daniel.dlds
The computer worked before. Is it possible that one of these capacitors went bad ? If so I have to get new ones. Or it is just a case of doing a better job of soldering them ?
I would be concerned the missing cap destroyed the video chip. It definitely needs to be there.
