have the GNU/Findutils ever been ported over?
Started by helf, February 14, 2008, 04:10:19 PM
http://www.gnu.org/software/findutils/
GNU package including find, locate, updatedb, and xargs.
I sorely miss being able to use locate :)
Shuren
findutils 4.1 (sources from 1994) compiles fine on NeXTStep 3.3. This week-end I make the package for Motorola and put it online.
Just for curious, from findutils' README:
Quote
The locate program and its helper programs are derived (heavily
modified) from James Woods' public domain fast-find code, which is
also distributed with the 4.3BSD find.  Because POSIX.2 requires `find
foo' to have the same effect as `find foo -print', the fast-find
searching has been moved to a separate program, `locate'; the same
thing has been done in 4.4BSD.
fast-find seems to be disappeared from WWW.
Hi, can you give me the URL to where you put it online? I didn't see it on the blog you have listed in your sig. Though i did find the HTTPS extension package for Omniweb 2.7-B3  which I hadn't seen before. Only HTTPS add-on I'd seen for Omniweb was for a newer version :)
btw, I tried the 4.1 sources on my machine and they would not compile.. I probably don't have something setup correctly...
Shuren
Quote from: "helf"Hi, can you give me the URL to where you put it online?
http://download.tuxfamily.org/greedydotfly/ns/a/unix/findutils-4.1.N.b.tar.gz
I haven't yet a scientific method (troubles with configure parameters and makefiles) to make packages :) then, in order to use "locate", you must add this line in your ~/.cshrc:
setenv LOCATE_PATH /usr/var/locatedb
and do it for every user in your machine. Don't worry, I make another package soon :)
Quotebtw, I tried the 4.1 sources on my machine and they would not compile.. I probably don't have something setup correctly...
Do you use this gcc http://www.savarese.org/patches/gcc.html ?
yeah, I'm using that version of GCC. I apparently had downloaded findutils v4.1.20 ... not the 4.1 sources.. the 4.1 sources seem to be compiling OK :)
Thanks!
p.s.
your package works great. thanks :)
Just FYI.  :D  I've packaged up findutils-4.1.20 that I've had compiled for sometime.  It's compiled quad fat w/ stock compiler for NS3.3, no -posix & updatedb has been modified to find the locatedb in /usr/adm/ since it's the common place on BSD4.3.   It's in the packages directory where everything else is packaged.  :wink:
