Main Menu
Rhapsody Developer Release
Started by skaffloth, December 29, 2009, 01:48:41 AM
skaffloth
I got the Rhapsody Developer Release for PC Compatibles (DR1?) and the Yellow Box for WIndows NT/95.
I thought it would be cool to install Rhapsody, but I can't mount the disc in Mac OS X or OpenStep 4.2, booting it from Parallels does not work as well.
Looking at the disk surface it looks like it doesn't contain anything = blank...
Could that be possible?
If so, where could you exchange one? Would Apple do it?
040 NeXTCube NeXTDimension
Turbo Color Slab
SparcStation 20 SX
HP 712/60 (Gecco)
bkmoore
I've never touched Rhapsody, but with NeXTSTEP and OpenSTEP, you need the boot floppies to mount the CD and start the installation.  I'm not sure which format the CD is, but I could only mount it in a NeXT environment, so I expect it is non-standard.
skaffloth
I couldn't mount it in OpenStep, it wouldn't mount the disk, that's why I am wondering.
I got hold of the boot disks for DR2,
found a place on the net where they had the whole DR2 for download,
not sure they would work for DR1?
Anyone know the location of boot/driver floppies for DR1?
Turbo Color Slab
SparcStation 20 SX
HP 712/60 (Gecco)
Quote from: "skaffloth"I couldn't mount it in OpenStep, it wouldn't mount the disk, that's why I am wondering.
When doing Rhapsody stuff, it is helpful to have Rhapsody documentation (like the RhapsodyAnswers set I put together for everyone). In that set of documents there is an RTF file called 00004-RDR_Filesystem.rtfd which says:
Rhadsody Developer Release Filesystem
TOPIC
The Rhapsody Developer Release (RDR) has a fundamental incompatability with OPENSTEP/Mach (and NeXTStep) that you should be aware of when planning how to install and evaluate this software. Specifically, RDR/Intel uses a different file system format than either RDR/PPC or OPENSTEP/ NeXTStep. You will not be able to set up systems to dualboot RDR/Intel and previous Mach/Intel operating systems. You will also not be able to exchange external hard disks and/ or removable media between RDR/Intel and other versions of Mach. Rhapsody/PPC will be able to read (mount read-only) media created on previous versions of Mach. Read/write access to older media is not supported.
DISCUSSION
The specific technical issues are as follows:
OpenStep/Mach (all versions) used the original m68k UFS file format, for all architectures. Where necessary (Intel, etc) it was programmed to do byte-swapping on the file system structures as it read them off the disk.
The DR1 release of Rhapsody (for both PPC and Intel) does not have this byte-swapping code in it, so the two systems are currently using incompatable file system formats. It happens that the PPC version has the same byte sequence that the original m68k system used, so that Rhapsody/PPC can read OpenStep/Mach disks created on any architecture. Rhapsody/ Intel can't read anyone else's disks.
In addition, the RDR native file system is based on the BSD4.4 file system. Previous Mach versions used the BSD4.3 file system format. The new file system supports huge (64 bit offset) files, and has some other changes. RDR only supports read access to the older file system.
Quote from: "skaffloth"Anyone know the location of boot/driver floppies for DR1?
You can download them here.
skaffloth
Ok, then it make sense that I can't see the disk...
Thx for the boot disks for DR1, I will try out my DR1 disk and see if I can get it installed.
Turbo Color Slab
SparcStation 20 SX
HP 712/60 (Gecco)
