The pursuit of usefulness in 2020
Started by BillAnderson, March 19, 2020, 08:02:35 PM
pomosapien
@codepoet80, thanks much for the Squid proxy repo.  I'm attempting to build/install it on a Pi 4, running into build errors that are probably fixable.  I can push up those changes to a fork if you would be interested in them.
codepoet80
That would be great! Also, be aware Squid 4 and up are a completely different beast than Squid 3.5 that I'm using in that repo and I found the config files were largely incompatible.
pomosapien
Indeed, I took it to be important that 3 be used for OpenSSL support.
And building our own Squid is important to be able to enable options at compile time.
For the non-Docker approach, I ultimately decided to tell today's GCC to treat the truncation bugs in 3.5 as warnings and not errors, by changing `configure` -- remove '-Werror' from C flags.
Also went back to the Docker approach and was able to get a container running, but I think that the master branch of that repo is a little borked; I had to alter the squid.conf construction code.  I think the port redirection is still not right despite, or because of, my changes.
crimsonRE
I know this is a rather late response as well, but summer/fall I spend as much time as possible outdoors. Winter is my playtime with the old old computers (versus the Apple Powerbook G4s running OS X 10.4/.5 that I use daily).
I do visit Gopher sites quite frequently for updated content - weather and news on gopher.floodgap.com and another site serving up CNN content. Also gopherpedia.com for fast peeks into Wikipedia...
BillAnderson
I'm the same @crimsonRE. Winter is for indoor nerdy fun, the other season for outdoor nerdy fun.
