Previous instruction trace/disassembly?
Started by cuby, April 26, 2020, 03:58:05 PM
I'm trying to (net)boot Plan9 under Previous (and also to recompile the Plan9 sources, this is already looking quite good for a cross-compile of the kernel on OS X, just the linker complains about something). Netbooting using the built-in slirp bootp support works well.
The first thing that had to be patched in Previous to avoid a Plan9 kernel panic was the address for SCR2, Plan9 accesses this at 0x0200d700 instead of 0x0200d000 (probably a mirrored address region). After that, the Plan9 kernel now hangs after accessing the floppy controller.
Here, it would be useful to have a CPU instruction trace/disassembly. There seems to be a "--trace" command-line option in Hatari, but I can't get this to work. Any hints are welcome...
I'm currently working with the sources from branch_mmu on sf, I suppose this isn't the current one?
-- Michael
gilles
I didn't touch the emulator for years but yes there is a full debugger in console mode. Maybe it's a compile option. What is your run platform ?
Quote from: gilles on April 27, 2020, 04:32:41 AMI didn't touch the emulator for years but yes there is a full debugger in console mode.
Thanks - I managed to get it to work by abusing the Command-Backspace (NMI) keyboard shortcut and calling Debug() from there... now I know the Plan9 kernel is hanging in a loop. So I have to create a disassembly of the Plan9 kernel (which is linked at a 68k Mach-O file, getting symbols is a bit difficult since I'm cross-compiling using Plan9 tools) to figure out where exactly... unfortunately, otool on OS X doesn't support 68k binaries any longer.
Quote from: undefinedMaybe it's a compile option. What is your run platform ?
OS X 10.14 - it seems that the Objective C GUI startup code that then executes SDL_main ignores all command line options.
gilles
I will try when I can but I'm not sure to have something that can run macosX 10.14 . Debugger from hatari could be used under linux. Also I'm nearly sure that I could start a maxosX binary with flags on another project sharing some elements with Previous (SDL + hatari gui) but maybe it was prior to the SDL2 migration.
gilles
ok it seems init was removed by someone (maybe for a macos issue)
in main.c
#if 0 /* FIXME: This sometimes causes exits when starting from application bundles */
   /* Check for any passed parameters */
   if (!Opt_ParseParameters(argc, (const char * const *)argv))
      return 1;
#endif
I suppose it's safe to re-enable for a local compile.
