Solitaire.3.2.NIS.gnutar.gz OPENSTEP Source missing
Started by wizard, June 01, 2020, 11:29:38 PM
wizard
Problem with Solitaire.3.2.NIS.gnutar.gz located at http://www.nextcomputers.org/NeXTfiles/Software/OPENSTEP/Apps/Games/
Despite instructions to build it in the readme in the same directory, and unless I am blind and just can't see it,  the archive is missing the source code to the OPENSTEP version. There is source for the older NEXTSTEP versions (101 & 102 etc). Anyone have or know where the source code to the OPENSTEP version is?
Regards,
Adam
nuss
This should be the latest source codes.
solitaire.zip
Had to use ZIP as Forum did not let me upload the original files.
ZIP contains:
829860 2005-09-06 10:36 Solitaire.3.2.s.gnutar.gz
1135282 2005-09-06 10:36 Solitaire.4.0b1.s.tar.gz
DON'T PANIC
Quote from: nuss on June 02, 2020, 03:18:26 AMHad to use ZIP as Forum did not let me upload the original files.
The forum was set to accept tar.gz files, but didn't allow it for some reason.  I added the .gz filetype to the settings so please let me know if that works.
wizard
That worked, thanks. Had to sign in to get the zip file.
