Previous working on Apple Silicon (natively!)
Started by larbob, December 30, 2020, 08:24:54 PM
Quote from: zombie on July 26, 2021, 10:04:10 PMI notice that the emulator bombs and runs more buggy when using 60ns memory instead of 70. Is there a chance that is bad interplay with the variable CPU speed?
Because Previous does not yet simulate memory timings the memory speed preference has no real effect. It just reports different memory to the guest system. What kinds of bugs or crashes do you experience? Can you reproduce the problems? If yes, it would be great if you could give me an instruction on how to reproduce it and I'll see if I have the same problem here.
zombie
Well to be honest, almost all the time when I run the NeXTdimension on a turbo cube, filled to the top with memory, set to variable CPU and 60ns memory in part, but even with 70ns memory. The bugs/hangs are random seeming, so not sure I can reproduce a particular action chain.
That said, the very same setup but using a next turbo color station instead, is significantly more stable.
What happens when the issue occurs? Does it only happen using variable CPU speed mode?
zombie
I haven't tried it with non variable. I will do so and report back.
What symptoms occur with the issue (kernel panics, crashing applications, drawing glitches, etc)?
dotsam
Just as a note, I was also able to build the current trunk version of Previous from https://sourceforge.net/p/previous/code/HEAD/tree/ along with sdl2, zlib, libpng, libpcap and cmake from Homebrew. I might even make a Homebrew formula to make this easier for others.
I originally thought there might be been an issue with the emulation as I was having strange issues compiling software, but after trying the same with an x86 build under Rosetta 2, I don't think it's the Apple Silicon part that's the problem (if Previous is even the problem).
Can anyone test if Performance is still the same in variable speed mode using the new SDL2 v2.0.16?
pomosapien
This is a cool result.
Even if you don't get more clock in the guest, being able to use less CPU on the host is beneficial, in terms of heat, battery and host multitasking.
ExFruityNextGuy
Hi All,
I've built a Apple Silicon native (no special workarounds required to use) version of Previous 2.4 (r1124). If anyone wants it DM me. Or you can just email (disposable address) helots06spacers (at) iCloud (dot) com
pomosapien
Did anyone do this?  What is the baseline for comparison?
Quote from: pomosapien on April 08, 2022, 02:11:18 PM> Can anyone test if Performance is still the same in variable speed mode using the new SDL2 v2.0.16?
This is no longer relevant. Thank you anyway.
pomosapien
Was messing about with variable clock mode. Statusbar speeds vary between 60 and 120 when compiling or downloading from the forum.  Ran nwbench:
Quote from: pomosapien on April 11, 2022, 01:10:50 PMWas messing about with variable clock mode. Statusbar speeds vary between 60 and 120 when compiling or downloading from the forum.  Ran nwbench:
For comparing performance between different systems and versions I do the following:
  • Configure Previous to simualte NeXT Computer (68030) with variable speed mode
  • Boot NeXTstep 1.0
  • Click and hold the title bar of the Workspace window
  • Wait until the Statusbar speed settles and note it
This is of course no real benchmark, but the easiest way for comparing.
thanks to forum member @ExFruityNextGuy we finally have a fully working universal binary of Previous! this is version 2.4 (r1124). do not forget to right-click -> open when starting the app for the first time on your Mac.
download:
https://mega.nz/file/U4J2iIBZ#FVitwoQZIewFhMAYfNGxSVgtns3NI8BvG-alnuJc7_g
Thanks, mike. I will put it on my site soon, after I test it on my M1 MBA.  I was meaning to get up with that user to grab that version.
