HTTPS for OmniWeb 3.0
Started by codepoet80, August 19, 2021, 06:58:17 AM
codepoet80
Was there ever an HTTPS plugin for OmniWeb 3? I found one for OmniWeb 2.x, but it does not work in 3.0
nuss
Hallo codepoet80,
HTTPS is already part of OmniWeb 3 (without any plugin), at least as far as I know (remember).
My installed OmniWeb shows HTTPS options in Info -> Administrator Preferences -> HTTPS-SSL
Anyhow none of the modern pages work due to legacy ciphers.
Greets, Nuss
DON'T PANIC
codepoet80
The HTTPS-SSL option is not present in my Administrator preferences, on OmniWeb 3.0
I have a work around for the modern cipher problem that works with other retro platforms -- a Squid SSL-Bump proxy does the trick and I DO see an option for setting up proxy servers in OmniWeb. But I can't use it because Omniweb refuses to open any HTTPS page with the error "OmniWeb doesn't natively understand https URLs and has no plug-in currently loaded to deal with them"
As mentioned, I tried the plug-in for 2.x, but it doesn't work.
What version of OmniWeb are you running, and are you sure you don't have any plug-ins installed? (Check in /LocalLibrary/OmniComponents)
nuss
Hallo codepoet80, you are right, seems that I have installed quite some plugins.
OmniWeb is version 3.1rc2. Maybe this helps in identifying the correct packages?
Cheers, nuss
DON'T PANIC
codepoet80
It does indeed! Thanks so much.
The next trick was finding a non-corrupt archive of OmniWeb 3.1 -- it seems most repositories are mirrors of Rob's, which had a bad package in it.
I have found all the necessary bits, and will figure out how to share for others in the future (or maybe Rob can update his share?)
