Main Menu
Mac OS X Server 1.2v3
Started by zsn0w, April 13, 2022, 12:27:16 PM
zsn0w
Hello,
Does anyone have a known-good image of server 1.2v3/rhapsody 5.6? I've been trying to install it on a graphite G4 and it just hangs every time using the only image I've found available online. When I have tried in on my beige G3, it will install but after the setup assistant it gets stuck in a loop of booting right back into the setup assistant and then crashing. Not sure what could be wrong besides the image being damaged. Any advice would be appreciated.
Zack
Is your pram battery good? I seem to recall the boot loop problem when my system would forget which partition was blessed. As a general statement I had -many- stability problems when I tried to run across various machines. Never could nail down if it was hardware, software, or just bad luck.
