Email solution for modern POP3?
Started by alobos, December 21, 2006, 04:53:44 PM
alobos
Hi.
I'm using OS X's mail.app, but I would like to use a mail app on Openstep. Is any app that authentifies via SMTP and handles more than one mailbox. Is there anything outside?
Cheers,
- Alejandro Lobos Kunstmann
ErikTheHack
Back in the day I used a little app called PopOver that would allow you to get mail from a POP3 server and import it into Mail.app -- it was quite cool actually and worked very well.  I can't recall if it supported multiple mailboxes -- as for the sending part, with mail configured sendmail worked just fine for outgoing stuff.
ND \'040 NeXTcube [SN: ABA0004306], NeXTStation Turbo Color ADB, HP PA-RISC 712/80, HP PA-RISC 712/100, Sun SPARCSTATION 5, Sun SPARCSTATION 20
