Multi-head in NS/OS on white hardware?
Started by kronoman, May 13, 2007, 04:42:16 PM
kronoman
Is it possible to use multiple monitors under OPENSTEP on x86? I know this can be done with a Cube and multiple ND cards, but how many of us are lucky enough to actually *have* that?
I assume that you'd need multiple physical cards, as AFAIK none of the drivers support multiple outputs on a single card. Also, could you mix and match, say, an AGP (or PCI-E - will that work?) Matrox G400 and two PCI cards that use the VESA driver?
