restoring NeXTstep MO
Started by Andreas, July 26, 2016, 11:15:13 PM
...i have three MO from NeXTstep 2.0, all in a good shape, but formatted and written with other stuff und unfortunatly untouched one.
As far as i can remember someone have backed up all NeXTstep versions, but i don't remember the place.
How can i write back some content on a working NS 3.3 cube to get a original NS 2.0 OD back?
download the system images:
https://mega.co.nz/#!h0IRgRLT!WiceqJA2LIhPbWJZvR6CmJstPZwOdZrun8gYo1e-Row
https://winworldpc.com/product/nextstep/
you first would have to restore the image to a harddrive, run the cube from it and afterwards use BuildDisk to write the OS to the optical disk.
regards,
michael
Quote from: "mikeboss"
that's what I wanted to avoid. isn't there any a command to the image restore, like dd if=image.img of=/dev/roda bs=something?
this won't work because it's a 2.0 GB image of a harddrive. I'm afraid that you'll have to go the route I described...
protocol7
In the absence of a dd image, there's a NS2.0 dump file here you can try.
Quote from: "protocol7"In the absence of a dd image, there's a NS2.0 dump file here you can try.
Thank you, i will try it. Seems there is other interesting software on this server
